lying nuetral light
Old Apr 20, 2008 | 11:06 AM
choochoo's Avatar
choochoo
Default RE: lying nuetral light
It's under warranty let the dealer fix it.
But sounds like a switch that has gone permanently closed.
Need to actually test the switch electronically to confirm it though.
It just might not be installed properly or some such other defect.
DON'T JUST JUMP TO CONCLUSIONS LIKE SO MANY OTHERS HERE DO!!
Old Apr 20, 2008 | 04:49 PM
skratch's Avatar
skratch
ORIGINAL: jethro001
I always pull my clutch in when I start mine in neutral, a dealer saw me do that and told me that was hard on my bike doing that. I can't believe that is true and I still always pull in the clutch.
it is harder on the bike if you are starting it with the bike in gear and just pull the clutch in.... but not if its in neutral.
Old Apr 20, 2008 | 06:13 PM
tailgater's Avatar
tailgater
[align=left]The 08 should not start when in gear without the clutch lever engaged. Maybe you have two problems.
ORIGINAL: CTB
[/align]
08 Ultra Screaming Eagle
Old Apr 20, 2008 | 06:44 PM
BillinNY's Avatar
BillinNY
Default RE: lying neutral light
Yep, if in neutral, clutch in before hitting the starter.
-Bill-
Old Apr 20, 2008 | 09:24 PM
mstecn's Avatar
mstecn
6th Gear
mine did that until i went with syn 3 in trannie lubed it right up nworks great rkc
Old Apr 20, 2008 | 10:26 PM
DiegoKing's Avatar
DiegoKing
Always pull the clutch in regardless of what gear I am in...bad memories of an old Sporty years ago...ouch!
emcelhannon
Apr 15, 2017 09:03 PM
MichiganDave
Aug 31, 2012 10:58 PM
douglas07UC
Feb 4, 2010 04:45 PM
powaypete
Aug 15, 2009 09:14 PM
