Hidden Antenna
Old Apr 22, 2008 | 07:21 AM
Puzzled's Avatar
Puzzled
Default RE: Hidden Antenna
I have tried the shorty's, Tune Trapper and powered antennas.
The shorty's were visible and the shorter you went the less reception you had. The billet 6" was useless. The generic rubber antennas worked the best.
The Tune Trapper (goes behind the fairing) worked very well onthe OEM radio and is worthless on an aftermarket radio.
The powered hidden antenna has worked well so far on my aftermarket radio. Not a whip antenna by any means however as good as a short rubber antenna.
Old Apr 22, 2008 | 07:25 AM
hoz88's Avatar
hoz88
Some friends have the Dakota they paid $75 for and I have an Advance Auto Parts powered antenna hidden in my fairing and it works 10 times better. Just my $.02.
Old Apr 22, 2008 | 07:28 AM
AtkRWC's Avatar
AtkRWC
Have the Biketronics version. Works ok but never had an external antenna to compare.
Old Apr 22, 2008 | 07:41 AM
DKSS07's Avatar
DKSS07
ORIGINAL: big_al
Hidden Antenna? not for me, I like the look of a remote control motorcycle
Too funny!
Old Apr 22, 2008 | 08:06 AM
rjmac53's Avatar
rjmac53
Have the hidden, works fine.
Old Apr 22, 2008 | 08:17 AM
maxflhx's Avatar
maxflhx
Put whip back on after using TT. I'm of the impression farring antennas work good inflat heavly populated areas. Mountian regonsand further into the boonies (or my driveway) got so good.
Old Apr 22, 2008 | 08:43 AM
Homebrew101's Avatar
Homebrew101
ORIGINAL: maxflhx
I think you hit it on the head here. I think the FM signal probably doesn't travel too far and stays fairly close to ground. If the stock antennae sticks up so much higher than any hidden one it will still pull in a signal after the hidden one has reached the outer limits which will happen sooner on hills than flat areas.
Pix
Audio Systems
Jan 24, 2023 07:14 AM
bgdv1
Audio Systems
Sep 15, 2011 01:24 PM
joe98
Aug 31, 2008 09:27 AM
restorick
Apr 11, 2008 04:01 PM
Easyglide
Jul 24, 2007 09:51 AM
