hidden attenas from ebay
Old Apr 28, 2008 | 09:24 AM
woodhaven glide's Avatar
woodhaven glide
Default hidden attenas from ebay
is anyone out there using the hidden attenas (high resolution) from e bay for about 50 bucks and are you happy with it.
Old Apr 28, 2008 | 09:34 AM
itsmyforte's Avatar
itsmyforte
Default RE: hidden attenas from ebay
I didnt pay $50, but I had a passive "tune trapper" and it didnt work worth poop in my bike. I tried it sitting still in my garage and its still not very good. The stock setup is the shizzle IMO. I put one on my standard and cut it down to the size i wanted for looks. It works like a champ!
Old Apr 28, 2008 | 09:36 AM
TexasRedneck's Avatar
TexasRedneck
How in the world is an audio antenna "high resolution"?!??
Me smells snake oil....
Old Apr 28, 2008 | 09:39 AM
woodhaven glide
maybe not high resolution I just worded it wrong
Old Apr 28, 2008 | 09:40 AM
HDDOC's Avatar
HDDOC
Antenna Test I use thwe crutchfield, bought it at Advanded auto under another name but same antenna and it works well around the metro area. Doc The whip is the best
Old Apr 28, 2008 | 09:41 AM
TexasRedneck
Bottom line....any "hidden" antenna WILL perform less well than a similar antenna that's exposed. Generally speaking, the higher it is, the better it will perform. To be sure, there's varying degrees of signal degradation - much depends on the area in which it'll be used. Here in the Texas Hill Country, it's VERY noticeable.
Old Apr 28, 2008 | 10:36 AM
rodmodder's Avatar
rodmodder
I'm using a hidden antenna from ebay and it works fine. I usually have my mp3 player plugged in but when listening to the radio it gets the job done.
Old Apr 28, 2008 | 11:02 AM
Crusher's Avatar
Crusher
Just tested the Tune Trapper VS. Stock antenna. The Tune Trapper is a WASTE OF MONEY. Got about 1/2 to 2/3 the number of stations the whip antenna got. If you stand near the tune trapper it works great. Just a little tough to do when your riding........
Old Apr 28, 2008 | 11:06 AM
lp's Avatar
lp
I use the powered hidden antenna you can buy at Pepboys for like 19 bucks.
There are more than a few of us that use it. I've ridden from Charleston to Daytona to Deals Gap etc and it works great. And without amplifying any noise..... just clean signal so far.
lp
Old Apr 28, 2008 | 11:08 AM
jefftrammel's Avatar
jefftrammel
I just took off my short 12" rubber antenna off my RG and installed the Tune Trapper. I get all the same stations I used to get. It works well for the money IMHO....but a Whip is always gonna be the best if you don't care about looks.
