Gas tank heating up
Old May 3, 2008 | 08:20 AM
strich's Avatar
strich
Default Gas tank heating up
this is day 3 for me with the SG, so i'm new to it.
But i noticed last night after about an hour of riding, that the under side of the tank was heating up pretty badly. I know the motor gives off some heat, but is it safe for the tank to be heating up that much?
It is full of flammable liquid. [:-]
Old May 3, 2008 | 08:41 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
Default RE: Gas tank heating up
Yes, there is quite a bit of heat.
If I leave my bike outdoors, any breeze seems to cool the tank and motor just fine.
But in my garage, I use a small floor fan directing the cooling air across the jugs and that seems to work well. I've done this with every bike I've owned and stored inside...just don't like the heat cooking things. Maybe a waste of time but works for me.
Old May 3, 2008 | 08:53 AM
Chicago Spike's Avatar
Chicago Spike
Yep, it will heat the tank some. But it is far from being dangerous. Gas itselfisn't flamable, it's the vapors/fumes that are flamable, and even then you need an ignition source for flame to happen. So as long as the tank doesn't get hot enough to boil and turn the liquid into a vapor, and that vapor doesn't escape, your tank and garage will be safe. If it does get hot enough to boil, stand waaaay back and watch the cool B.L.E.V.E. (Boiling Liquid Expanding Vapor Explosion )
PS....Have your camera ready for that
flangar
Nov 30, 2017 01:41 PM
I'maHugger
Sep 15, 2013 02:50 PM
Blackysporty
May 8, 2012 09:42 AM
mrodff
Jan 25, 2011 07:19 PM
kingbobtex
Jan 17, 2011 11:14 PM
