Help with removing pipes
Old May 4, 2008 | 11:07 AM
Rabid's Avatar
Rabid
Default Help with removing pipes
Folks, I'm trying to remove the factory slip-ons. I've loosened/removed the three clamps that hold it on, but that sucker is stuck in there. Tried using a block of wood with a hammer to try and break the seal, but no go. I'm afraid to put too much torque on the pipe because the cross over pipe isn't secure and springy.BTW it's the left (fake) slip on I'm removing right now. I'm going to have a cold one now to see if the gurus can give me some ideas.
Old May 4, 2008 | 11:15 AM
dgriffith's Avatar
dgriffith
Default RE: Help with removing pipes
I sprayed mine with Rustbuster and set down facing the bike, with my foot on the muffler joint. grabbed the end of the muffler and pulled it sideways a little. It didn't take much, mine came loose. Hope this helps.
Old May 4, 2008 | 11:16 AM
MNPGRider's Avatar
MNPGRider
I once had a set of Trident headers stuck on the heads. I called Mike the Mechanic at Baxter's in Marne Iowa, and he told me to use Sea Foam "Deep Creep." It is a foaming penetrating oil.
It worked.
To take off my Ultra Slip-ons, I did have to rock them back and forth, up and down quite a bit, even after using the Deep Creep. Theyhave a slotted end that squeezes together with the clamps, and it seems you have to get that to spread a little to get them off.
Old May 4, 2008 | 11:19 AM
Major Bill's Avatar
Major Bill
I just replaced my stock slip-ons yesterday with some shiny new Rineharts.
Initially I had the same problem. It wouldn't budge. I sprayed some good ol' WD-40 where the muffler pipe slides on to the header pipe and it was good to go. Spray it on, let it work for about 1 -2 min and then it should start to break free.
sportyrider1's Avatar
sportyrider1
PB blaster http://www.lowes.com/lowes/lkn?actio...34-56167-20-PBfor one. it is available most anywhere.you say the three clamps. do you meant the 1 pipe clamp where the muffler clamps to the head pipe and the 2 bracket bolts under the bag? gently rock the muffler back and forth and twist until you open the clamp area up then twist as you pull.
Old May 4, 2008 | 11:23 AM
sifularson's Avatar
sifularson
Twisting it will help. Sears makes a rubber strap wrench that you can use. Believe me, you'll use the wrench in the future. They don't cost much and will save you a lot of grief. if you pound on the muffler you'll ruin it.
Old May 4, 2008 | 01:14 PM
lecomte38's Avatar
lecomte38
+1 twist action with PB Blaster. +2 ror the sears rubber strap wrench set. ( one of them is RED )
Old May 4, 2008 | 01:24 PM
brshrideevo88@aol's Avatar
brshrideevo88@aol
Done lots of pipes...PB BLASTER--let sit for a beer-- and twist while removing..Don't forget the silver anti-sieze when going back toigether.
Bradd
hscic
Mar 2, 2015 03:44 PM
T_Sebastian
Dec 18, 2011 12:32 PM
PostalRoadKing
Jun 10, 2011 04:04 PM
robaube
Feb 22, 2008 10:44 AM
lilrooster76
Exhaust System Topics
Jul 18, 2007 08:23 AM
