Dyno - exhaust popping question
Old May 6, 2008 | 08:33 AM
tah796's Avatar
tah796
Default Dyno - exhaust popping question
Help needed for a technically challenged HD rider. Got a power commander, K&N air intake, and custom baffles from fuel moto. Jamie sent me a custom map along with thePCIII.Can not get rid of popping on decel. After trying to change the numbers in the zero column which didn't work, Jamie said to check for exhaust leak. I got the slip on clamps as tight as I could, no luck with popping. Then I went to the STEALERSHIP who has a Dynojet tuner machine. After $170 and them claiming I got +5 HP and +5 Torque, it still popps on decel. I just noticed when comparing map numbers that Jamie's map had a seperate map for each cylinder with some numbers varying quite a bit, however, STEARERSHIP only had one map covering both cylinders. Most of the numbers were an average of Jamie's numbers with a few other changes. Gas mileage went from 39 with Jamie's map to 34 with MOCO's map. Questions are: How do I get rid of popping and is there a better dyno available in Southern Maryland from the stinkin MOCO's? Thanks for any advice you can give.
agove
16
Apr 9, 2013 03:23 PM
Rabbs00
Apr 30, 2011 10:03 AM
ultravista
Exhaust System Topics
Sep 24, 2009 11:30 PM
jrdfatboy
Jul 14, 2009 12:42 PM
dnewman007
Mar 26, 2007 09:17 PM
