HOW BOUT THIS
Old May 7, 2008 | 07:10 PM
dgoodbmw's Avatar
dgoodbmw
Default HOW BOUT THIS
Anyone ever have their 08 just plain shut off under acceleration, around 2500rpm. I was leaving a store today and pulled out onto a 4 lane highway and was accelerating normally when about 100 yards up the road the machine died, totally. luckily i was able to get off the road, while scratching my head, i made sure i hadnt hit kill swith and ign was still on. I tried to restart without shutting ign off,crank but no start. Shut ign off then on as normal routine, when engine light went off, machine started. I am taking in to dealer mon for them to read code, (there is a code), but im thinking about some enormous truck behind me when this happened, luckily there wasnt one, this is DANGEROUS..
Old May 7, 2008 | 07:27 PM
Jinks's Avatar
Jinks
Default RE: HOW BOUT THIS
I've had Harleys (& various other brands) turn themselves off for no apparent reason quite a few times. Sometimes I've found the cause, other times it remained a mistery. Truck, car, or motorcycle it's never a good idea to pull in front of a large fast moving vehicle, but motorcycles do have less protection.
Old May 7, 2008 | 07:41 PM
Erdnase's Avatar
Erdnase
03 roadie did it sporadically, was a safety recall on a circuit breaker (?). dealer took 30 min. to fix.
Old May 7, 2008 | 09:03 PM
jcbpa's Avatar
jcbpa
I only have 1000 on my 08, but I am grateful that never happened to me. I'd like to know if it is a recall, please let me know what the dealer finds. Best, J
Old May 14, 2008 | 02:04 PM
dgoodbmw's Avatar
dgoodbmw
Default RE: HOW BOUT THIS (UPDATE)
I just picked this machine up after having the dealer look for the problem, unfortunately, they could find nothing. The code in the computer was not able to direct them to the happening and even though the code came as a result of the dying, it didnt give a firm destination of the problem. They checked fuel supply pressure, and sending unit, etc, all good. They also got harley on the phone and even hd could not do more to guide them. Im comfortable that the dealer put the correct amt. of effort into this but came up empty. I will have to be very careful on the road for awhile anticipating a reoccurrence, but, life goes on. One important thing should this happen to someone else, LOOK TO SEE IF THE LIGHTS ARE ON, this tells tech if the problem is elec. or fuel.
Old May 14, 2008 | 02:32 PM
Mississippi Bagger's Avatar
Mississippi Bagger
ORIGINAL: dgoodbmw
HOLEY MOLEY!
Every time I am on my bike I am of the mindset that everything (other bikers, cagers, critters, road conditions AND my bike) is out to kill me.
No, this does not take away from the pleasure of riding, it is just a defensive riding mindset that has kept me accident free for over 29 years.
Not saying that **** can't happen, but I do my best to anticipate every possible dumbass move by others on the road, poor road conditions, and failure of a component of the bike.
Old May 14, 2008 | 04:01 PM
dcountryboy's Avatar
dcountryboy
ORIGINAL: Mississippi Bagger
ORIGINAL: dgoodbmw
HOLEY MOLEY!
+1
Ihavent had my 08 do it but I had an06 Road King do the same thing usually at a stop though no reason just die.I also couldnt restart till turning kill switch off and then back on.Very embarrassing but safer than what yours did while on the road.My service dept also I am sure did all they could to find but nothing .Luckily it was not very often just occasionally.Please keep posted as to if you find anything
Old May 14, 2008 | 04:20 PM
MyFirstHD's Avatar
MyFirstHD
I remember seeing a post about a faulty tip sensor that kills the bike when it's dumped. If I remember correctly, when the bike is dumped you need to turn the power completely off to clear the fault and then start the bike, not just hit the starter again.
I don't know even know if I read about it on this site. Sometimes a sudden acceleration or bump caused the sensor to think the bike had tipped. I don't remember the whole story but it ended with the guy getting the sensor changed under warranty and the problem went away.
BreakoutANX
Apr 22, 2018 04:18 PM
streetglide clyde
2014-2024 Touring Models
Mar 29, 2014 09:11 PM
Travlinman314
Aug 22, 2009 11:43 AM
turtleman57
Apr 30, 2008 09:47 PM
GADave
May 10, 2007 09:48 AM
