tank bra
Old May 7, 2008 | 08:47 PM
SPARKY01's Avatar
SPARKY01
Default tank bra
probably should have asked before i bought but just received hd tank bra for my 08 classic. as usual, hd instructions suck. whats with the front strap. looks like the rear one goes under frame @ rear of tank but inst. say front on goes over front of tank. looks like it will slide all the way back towards rear of tank only hanging up on top of cylinders. am i missing something here?
also. bought this because jeans are scuffing paint on tank especially when i have my feet on the highway pegs. am a little concerned that this bra with do more damage than not using it! let me know what ya'll think!!! thanks
Old May 7, 2008 | 09:03 PM
ripper43's Avatar
ripper43
Default RE: tank bra
They don't fit for ****.......... I took mine back to the dealer. and yes the instructions suck out loud.
Old May 7, 2008 | 09:19 PM
Nellybelle's Avatar
Nellybelle
I have one. I took it off after reading here that gas and crap somtimes get trapped under bra and scratches finish.
I was just thinking about puttining it back on when I read your post. Think I will wait and see what others have to say.
Old May 7, 2008 | 09:20 PM
Dispatch's Avatar
Dispatch
ORIGINAL: SPARKY01
I had one for my 2003 Electra Glide standard. I still have it.I never putit back on the bike when I sold it 3 months ago.If you'd of posted thisbefore you bought it, I'd of sentyou mine for nothing. Just pay the shipping.Yes, The long strap goes completely over and around the front of both sides of the tank. Put the back part on first.The other two littlestraps go under the frame, under your seat. Attach the 'S' clip through the looped end of the other little strap. You have to pull the vinylup from time to time as it slips down when you ride. I didn't think much of mine. I used it twice and put it on the shelf after a wash. Mine held sand and small road debris when I rode. Then again, I am in Florida. As you know, it is cotton lined. It will give you some protection but you have to check it and clean it often. Oh, and let it air dry or it will shrink up on you. Hope this helps. [sm=signs003.gif]
Old May 7, 2008 | 09:35 PM
roadking2014's Avatar
roadking2014
3m clear bra...they make a pre cut kit for the gas tank.....check and see if there is an installer in the area....
Old May 7, 2008 | 09:43 PM
jahays32's Avatar
jahays32
+1 on the 3M paint protection. If the bra gets sand down in it your paint will suffer plus they are ugly.
I looked in the phone book and got the fairing, tank, lowers, front fender, tour pac and bags done for $250.00
Old May 7, 2008 | 09:47 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Crappy Fit for sure... And like any Bra on the Putt will cause paint damage in time... Dust & sand will make it's way under the Bra and will break down the paint over time... If you do use any of them make sure you clean and put a extra heavy coat of wax on the areas to be covered... Make sure you take them off and clean & re-wax on a regular basis
Old May 7, 2008 | 09:58 PM
SPARKY01's Avatar
SPARKY01
thx...trhink i will put it away til paint is screwed up from normal wear and tear.. love this forum and all the help i get!!!
Old May 7, 2008 | 10:04 PM
Dispatch's Avatar
Dispatch
Use it but with caution. Check it after every ride. If it show wear then discard it.
Old May 7, 2008 | 10:05 PM
greg09997's Avatar
greg09997
I like mine. They're easy enough to remove to clean under & I think the damage will be less than the scuffing my knees were making on the tank. Keep everything clean and you'll be fine.
G-
