Rear air shocks bleeding down
Old Feb 21, 2006 | 05:58 PM
blukrom's Avatar
blukrom
Default Rear air shocks bleeding down
Question, is it common for the air to bleed down after a few weeks? I usually run about 10 lbs in mine and every time I go back and check they are down to zero. I checked all the fittings and they seem tight. Is this normal?
Old Feb 21, 2006 | 07:27 PM
CHEYENNE's Avatar
CHEYENNE
Default RE: Rear air shocks bleeding down
No, sounds like you have a leak somewhere. If the bike is still under warranty get them to the dealer to get replaced OR just spend the money for some Progressive 440's
Old Feb 21, 2006 | 07:30 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
I had trouble with the brass connector at the top front of my shocks (where the line goes in). That's a good place to start.
Old Feb 21, 2006 | 07:53 PM
Pauljr's Avatar
Pauljr
Good luck with the Warranty. Buddy of mine bought the 7 year ESP( BIG BUCKS ) and the rear went. The rear shocks are not covered. B.S. He was slightly over 1 year. Dumb *** bought replacement rear shocks. No way would I have paid the MOCO for that one.
Old Feb 21, 2006 | 07:56 PM
blukrom's Avatar
blukrom
I didnt think it was right but thanks for confirming.
I guess I will pump them up and put some soapy water around all the fittings and look for bubbles, at least then I can point the dealer to the right spot and let them warrant it.
What are the Progressive 440s? Are they the same type of air set up or are they just an oil dampend shock with progressve spring? I guess the big question is did you notice a big difference after installing them?
Old Feb 21, 2006 | 08:08 PM
CHEYENNE's Avatar
CHEYENNE
I haven't bought/installed them YET, but everyone that has says night/day difference. I will be buying mine before spring.
Old Feb 21, 2006 | 08:14 PM
Terry TK's Avatar
Terry TK
READ THIS
Old Feb 21, 2006 | 08:24 PM
blukrom's Avatar
blukrom
Terry that link seems to be broken???
Old Feb 21, 2006 | 08:41 PM
Terry TK's Avatar
Terry TK
Here Ya go. I fixed it above too.
Click HERE
Old Feb 21, 2006 | 10:22 PM
jeepster09's Avatar
jeepster09
You will be amazed how much better your bike rides and handles with quality shocks on it over the factory air shocks . Plus no more fiddling with air pressures.
