simple, maybe, FLHTCUI
Old May 8, 2008 | 06:11 AM
xoff's Avatar
xoff
5th Gear
Default simple, maybe, FLHTCUI
I recently "lucked up" on a 99 FLTHCUI. I had to replace the handlebar, inner, and outer fairing. The bike ran great all electrics worked before I began. Now it won't start.(turn over) The fuel pump doesn't work nor the front lights. Not even the dash lights. The horn works, the rear light works, the rear turn signals work. I have rechecked every plug and every fuse. Nothing. Have I walked into a loop or is this another secret Harley thing. Thanks for any help.
Old May 8, 2008 | 06:21 AM
stro1965's Avatar
stro1965
Default RE: simple, maybe, FLHTCUI
How long did it sit? Is the battery shot?
Old May 8, 2008 | 06:31 AM
spence222's Avatar
spence222
I'd go a step further than just checking the fuses.....I'd replace every fuse!
Old May 8, 2008 | 06:32 AM
spence222's Avatar
spence222
Double check all your grounds too.....
Old May 8, 2008 | 07:57 AM
OD_Cleaver's Avatar
OD_Cleaver
It worked before you touched it. It dosen't work now. Recheck your work.
Disconnect and reconnect each connector. Make sure that all the wire terminals within the connectors are fully seated.
If that fails, disconnect the battery and ring out each circuit with a ohmmeter.
OD
Old May 8, 2008 | 11:19 AM
hamnhog's Avatar
hamnhog
May be multiple wiring issues, but first, check the KILL switch wiring very carefully. That would cover the fuel pump and no start and maybe some of the other problems. Could be a pinched wire or maybe an open wire.
Old May 8, 2008 | 03:25 PM
xoff's Avatar
xoff
5th Gear
I finally found the problem. I am not going to put the radio back. That is the problem. Without the radio installed and ground nothing from the starter forward works!!!!!!!!!! Another Harley thingie. Any ideas? No I don't want the radio in if there is a work around.
Old May 8, 2008 | 05:01 PM
xoff's Avatar
xoff
5th Gear
Problem Ided, solution was looping the ground at the radio plug. It supposedly was wired that way only on the 99s. Thanks again.
skydrifter
Jul 20, 2016 01:52 PM
iRider
Electrical/Lighting/Alarm
17
Jun 8, 2015 07:28 AM
TReaper
Nov 18, 2014 12:16 PM
bakednormals
Jan 19, 2013 09:45 AM
97chopper
Jul 12, 2007 02:35 PM
