need help bike is shuting down on me
Old May 11, 2008 | 11:39 AM
peppi's Avatar
peppi
Default RE: need help bike is shuting down on me
It's the main breaker, if it were the fuse it would not reset as you say after a few minutes.
It was upped from 40 amps to 50 amps a while back.
Old May 11, 2008 | 09:36 PM
firstimer's Avatar
firstimer
can that be happining to my 02 roadking? same problem. dealer thinks it is a pinhole in the fuel line, but seems more electrical to me, but what do i know. this is my first ride on two wheels.
[IMG]local://upfiles/58852/DF5F3137570342D6B61072D212CDAAFB.jpg[/IMG]
Old May 11, 2008 | 09:41 PM
uweldit's Avatar
uweldit
I think it's the ignition switch.
Think of the ignition switch as "all roadslead to Rome". Everythingthat makes the bike run and light up goes through it.
I don't think that the breaker/fuse is bad unless it is blowing. If that's the case the voltage regulator/stator would need to be examined.
Old May 11, 2008 | 09:46 PM
Medicfrost's Avatar
Medicfrost
That recall included 2002s also. Here is a copy of the NHTSA's report.
http://www-odi.nhtsa.dot.gov/cars/pr...estype=VEHICLE
Old May 11, 2008 | 10:32 PM
uweldit's Avatar
uweldit
Wow, I just learned something!
Old Jun 11, 2008 | 10:24 PM
firstimer's Avatar
firstimer
replaced the circutbreaker to the 50 amp and prob. solved
Old Jun 11, 2008 | 10:32 PM
Little Mike's Avatar
Little Mike
Buddy of mine had the same problem, took it to the stealer and they replaced the ingition switch. It died again on the way home. Turned out it was the circuit breaker, it sits infront of the battery thus behind the rear jug and when it gets hot it trips. Give it a few minutes&nbsp\\;to cool and it will reset. On the '04s they went to the maxi-fuse because of this problem. He just replaced the circuit breaker with the maxi-fuse.
Old Jun 12, 2008 | 10:04 AM
garyhendley's Avatar
garyhendley
i keep a spare fuses on my bike
Old Jun 12, 2008 | 03:08 PM
Twospeeds's Avatar
Twospeeds
Stage I
This may not be applicable to an 03, but my buddy had an 01 with very similar problems. After the dealer kept throwing parts at it, including a new ECM, we found some internet talk about a problem with the tip sensor. Dealer kept saying no, that's not it, but after they had it for 2 weeks on their dyno trying to find the problem, they proclaimed they had found the problem and replaced the tip sensor....no more problems.
&nbsp\\;
Papa Bear
May 15, 2017 09:29 PM
pickenup
Sep 10, 2014 01:44 PM
fishn4life
May 6, 2012 12:29 PM
jwyrem
Nov 20, 2011 05:23 PM
1.HD.ROCKS
Apr 6, 2010 07:19 AM
