Trailering
Old May 11, 2008 | 08:52 PM
cwglide06's Avatar
cwglide06
Stage II
Default Trailering
OK, finally back into my dream Harley. I'll be trailering it along with my wifes bike. The problem is, how do you tie a ROADGLIDE down. I have a Rance trailer with the black, flip-up covered front wheel wells.
This system has worked fine with my previous ride. But that unit didn't have a fairing.
Without chaging to a different form of front tire clamping system, what options do I have?
Chris W.
Windsor, CT
'06 Roadglide
Old May 11, 2008 | 08:57 PM
Medicfrost's Avatar
Medicfrost
Default RE: Trailering
The best option I can come with is forget the trailer, and ride them!!!
Old May 11, 2008 | 09:07 PM
Steve On 3's Avatar
Steve On 3
+1 It's a ROAD glide dude not a trailer glide. Ride it. Pretty soon their gonna be calling it trailer week for heaven;'s sake
Bubba
Old May 11, 2008 | 09:12 PM
Dogs of war's Avatar
Dogs of war
I'm sure he has his reasons for needing to trailer them and it's really non of our concern. He's asking for help with a problem and he gets these .02 from you guys that aren't worth that. Good going guys and way to contribute to the forum.
Old May 11, 2008 | 09:19 PM
Andy Engemann's Avatar
Andy Engemann
ORIGINAL: Dogs of war
+1
Andy
Old May 11, 2008 | 09:21 PM
Steve On 3's Avatar
Steve On 3
I suppose your opinion is worth more than .02 right? If you buy a touring bike, it is designed to be ridden while touring. Touring suggests more than the local bar on Saturday night. If he had said he was ridng a chopper, I can understand that...who can ride that for distance. His lack of responses could be because nobody actually trailers a Roadglide. Lighten up Francis
Bubba
Old May 11, 2008 | 09:34 PM
serverpimp's Avatar
serverpimp
I was on looking for some pointers also as I have a reason to trailer my bikes, 2 bikes to getfrom point A to pointB so my father can ridemy wife's FLHX.But it's really no bodies damn business why I have to trailer or not. I just don't get the folks that have to muddy the forums with the same ol' BS answers. Go somewhere else as it's not wanted here.
I will keep looking and check back here to see if someone offers up real advice.
Old May 11, 2008 | 09:36 PM
Qball's Avatar
Qball
On my EG I go under the fairing and over the triple tree down to my d-rings. I use powerTye straps that have the soft loops on them.
Old May 11, 2008 | 09:44 PM
serverpimp's Avatar
serverpimp
I found this previous thread that has some good ideas. https://www.hdforums.com/m_1840397/tm.htm
Old May 11, 2008 | 11:20 PM
Big Cholla's Avatar
Big Cholla
cw: I also have an '08 Road Glide that for my own purposes I have to trailer once in a while. I found it best to use a CyclePro Chock at the front wheel, a runner on each side of the rear wheel to prevent 'walking' one way or the other and ratchet tie-downs with the soft loop built-in. I pass the soft loop over the engine protection bar between the outside fairing clamp and the frame. I then pull about 1 1/2 inches down on the front suspension. I also tie down the rear with the same ratchet tie-downs only the soft ties are passed over the tour-pak lower loop. Be careful with the rear tie down straps while positioning them so they will not rub against the saddle bags. I do not pull downward as hard on the rear suspension as the front. I have hauled all sorts of dirt and street bikes all over the USA using this system in pickup trucks, open trailers and closed trailers. I have never had a problem.
You will read screams of 'don't do that' from others here on this forum about compressing the front forks. It is total nonsense to worry about a little compression. That is what the forks are designed to do. I just wouldn't trailer the bike with ALL the travel taken up on the front forks. .................. BC
