I have had my mufflers off at least 3 times and still no leaks, probably will replace with OEM the next time I need to remove them, then I probably will have a leak...
Ditto...Clamps are good for one crush only....You shouldn't need sealant
milo8155
07 FLHX
03 FXST
Collierville, TN
Wrong, I've used clamps over and over with plain clear silicone and not had any leaks. I replace them when they look crappy but they WILL seal more than once. Torque them to 55 ft lbs!
I've never used a sealant, I'vealways relied on just clamps. I've so far, knock on wood, have been lucky to not have a leak. I wouldn't hesitate on using Permatex if I did have a leak though.
