Slip-on "Sealant"
Old May 14, 2008 | 11:45 PM
PapaTravis's Avatar
PapaTravis
Default RE: Slip-on "Sealant" AND mounting position
I just had my drag pipe slip ons off the bike to put in some lollipop bolts. I had the same discoloration, at the clamp. I cleaned the pipes the best I could, but am past the point of getting them completely back to normal. When I put them back on, I used some high temp RTV silicone. Seems to work just fine. I am into the older look, on bikes. I had this thought of removing the heat shields, and wrapping the pipes with tape. Figure I can down past the clamp joint, leaving just the last two feet of pipe exposed. Still thinking about it, as I have not seen wrapped pipes on a bagger. The wrap is cheap, about $60, so I figure if I do not like the look, I can take it off and get the hot jet coated.
Old May 15, 2008 | 02:20 AM
Avmech97's Avatar
Avmech97
bezoar- if you don't position the muffler support brackets under the bags at the right spot (centered) you will get more vibration than normal.My RG is a lot smoother with the hanger support bracket centered. Ride Safe![sm=biker2.gif]
hOtroDD77
Feb 6, 2016 10:43 AM
trnewman
Aug 29, 2012 06:46 PM
WVNightster
Sep 19, 2011 06:45 AM
Mathews2
May 31, 2007 05:39 AM
cornholio
Apr 1, 2007 02:59 PM
