Slip-on "Sealant"
Old May 14, 2008 | 04:32 AM
buzzard07's Avatar
buzzard07
Default Slip-on "Sealant"
Hi all,
A quick question? What is the best sealant to use for my new slip-ons? I have them on already but after a few hundred miles I can see where there is a slight leak at the junction, and I'm getting some minor decel popping. The clamps are tight so I figured I would try some sealant. Any advice would be very helpful....Thanks B
Old May 14, 2008 | 04:46 AM
relli's Avatar
relli
Default RE: Slip-on "Sealant"
skip the sealant and replace the clamps
Old May 14, 2008 | 05:27 AM
maineultraclassic's Avatar
maineultraclassic
Permatex sells high temp copper exhaust sealant, it's gold in color. Put a bead around the muffler inlet before sliding it on the header pipe, tighten down the clamp, and let it sit overnight to cure.
Steve
Old May 14, 2008 | 05:38 AM
radridd's Avatar
radridd
X2 on permatex copper
Old May 14, 2008 | 05:57 AM
buzzard07's Avatar
buzzard07
Ok ,Thanks alot Guys I appreciate the help.... Ride safe...... B
Old May 14, 2008 | 06:58 AM
frog13's Avatar
frog13
I like the Permatex copper, although you really shouldn't need it. I do it just for my own "feel good", just a very small bead, just below the pinch slots. Also, I make sure the clamp is only on the muffler as far as it needs to go, avbout 1/16" from the end to get maximum clamping.
Old May 14, 2008 | 08:20 AM
maxflhx's Avatar
maxflhx
I'd recomend replacing the clamps as well. The stock clamps don't hold upafter removal.
Old May 14, 2008 | 08:54 AM
bezoar's Avatar
bezoar
Default RE: Slip-on "Sealant" AND mounting position
I'm about to add some V&H slip on's and had the same sealant question, so I'm glad someone ELSE asked it ;-).
Now for my question. I would ***-U-ME that you put the V&H on in the same position (the brackets) as the OEM pipes. Someone wrote in that he had but a pair of aftermarket slipons on and had a lot of racket because he hadn't tightened the brackets in the center of the mounts. Is there any truth to this or does it matter at all-whew!
[IMG]local://upfiles/38807/D868E35A703B471AB975F3D4DC7E5FD2.jpg[/IMG]
Old May 14, 2008 | 11:58 AM
milo8155's Avatar
milo8155
Ditto...Clamps are good for one crush only....You shouldn't need sealant
milo8155
07 FLHX
03 FXST
Collierville, TN
Old May 14, 2008 | 02:38 PM
GScotty's Avatar
GScotty
I put Vance & Hines slip ons onmy 08 Ultra with no sealant.. So far no leaks but if I did it again or if they start leaking I would go to the Harley store and get Harley clamps. The Harley clamps looked superior to the Vance and Hines
ORIGINAL: bezoar
