Fix my hog (discount coupon code)
Old May 16, 2008 | 07:08 AM
08HD's Avatar
08HD
Default Fix my hog (discount coupon code)
'bout to order fix my hog Harley Davidson Touring - 2 Disc Set, wanted to know where can I get a coupon code to save a few bucks. If anyone knows please respond or is this one of those you have to buy first and then we give you a discount code on the next order deals?
Old May 16, 2008 | 08:01 AM
hduc2005's Avatar
hduc2005
Default RE: Fix my hog (discount coupon code)
I bought the touring pack a couple over weeks a go and there great video's but I have no use for the bolt on performance dvd so if any one wants to buy it let me know but both dvd's are great.
Old May 16, 2008 | 09:31 AM
rjgraham's Avatar
rjgraham
ORIGINAL: hduc2005
so that DVD doesn't cover maintenance?
Old May 16, 2008 | 10:01 AM
hduc2005's Avatar
hduc2005
the Touring Bolt-On DVD covers some pipe install, dynojet install and a total of 6.5 hrs over other install add-ons
the other dvds covers many maintenance items.
here is what bolt-on dvds cover:
DISC 1
RUN TIME: 2 HOURS 23 MINUTES [ul][*] Intro[*]Fairing Removal[*]Dakota Digital Gauges[*]Barnett Clutch Cable[*]Barnett Throttle Cables[*]Wimmer Air Intake[*]SuperTrapp 2:1 Exhaust[*]Power Commander[*]Goodridge Brake Lines[/ul]
DISC 2
RUN TIME: 2 HOURS 23 MINUTES [ul][*] Goodridge Brake Lines #2[*]SuperTrapp’s SuperPak – Slip-Ons / FI Control / Air Cleaner[*]Headwinds Custom Headlight & Passing Lamps[*]SuperTrapp 2:1 Exhaust[*]Dynojet Thunderslide & Jet Kit[*]Power Commander [/ul]
DISC 3
RUN TIME: 2 HOURS 10 MINUTES [ul][*] Chrome Inner Primary[*]Barnett Scorpion Clutch[*]Barnett Polished Outer Primary[*]Mikuni Full Carburetor Kit[*]Mikuni Easy Carb Kit w/ Wimmer Air Intake[*]Interview w/ Chris Maida about Performance upgrades and the EPA[*]FAQ w/ Manufacturers[/ul]here is what is on the maintenance dvds
[ul][*]Tools and Products[*]Seat Removal & Battery Check[*]Oil and Transmission Fluid Service[*]Throttle Cable Lubrication & Adjustment w/ Air Filter Replacement[*]Primary Fluid Service w/ Clutch &[*]Primary Chain Adjustment[*]Spark Plugs[*]Front Fairing Removal[*]Front Fork Removal[*]Steering Head Bearings[*]Fork Fluid Service[*] Front Fork Reinstall[*]Front Brake Calipers & Pads[*]Rear Brake Caliper & Pads[*]Rear Tire Removal & Replacement[*]Safety Check[/ul] EVOLUTION SOLUTION[*]Rear Brake Caliper & Pads[*] Front Brake Calipers & Pads[*]Front Fork Fluid Service Conventional Front Forks[*]Outer Fairing Removal
[/ul] BONUS MATERIAL[*]Battery & Charging System[*]Turn Signal Brake Light Module Conversion Kit[*]Draining Fuel & Fuel Tank Filter[*]Rear Shock Absorbers / Air Suspension / Fuse Box[*]Bug Removal[/ul]
Old May 16, 2008 | 10:21 AM
RoadKing_Al's Avatar
RoadKing_Al
My son and I purchased the Maintenance Touring Edition set and the Touring Bolt-On set. Great DVD's, if your afraid of wrenching it these DVD's with get you through it.
Forgot, the discount coupon came with the order.
Houston_t
Audio Systems
Jun 2, 2016 09:37 AM
zeus33
J&M Motorcycle Audio
Jan 18, 2013 10:53 AM
Aummy
Jun 1, 2008 08:45 PM
Dale Franks
Mar 26, 2008 01:43 PM
ericsenf
Nov 29, 2007 11:26 AM
