Idle Problem?? - Where to start......
Old May 20, 2008 | 11:09 AM
mgoblue3's Avatar
mgoblue3
Default Idle Problem?? - Where to start......
Have an 01 Road King Classic. When at a stop sign (and basically in first gear) the bike is stalling). It appears that when i open the throttle and let it snap closed it sometimes will close all the way causing the stall, but occasionally (when parked) it will not close all the way and when i twist it to close all the way the idle starts really slowing down and then stalls...........your thoughts on where to start to diagnose this problem will be much appreciated.
Thanks mgoblue3
[IMG]local://upfiles/32207/9790105075F54528AAA674EAB48057B2.jpg[/IMG]
Old May 20, 2008 | 11:13 AM
hoosierhog88's Avatar
hoosierhog88
Default RE: Idle Problem?? - Where to start......
Hmmm. Could be a carb or cable problem. Start by checking the throttle cable and work backwards. I'm assuming it's a carburated model and not fuel injected.
And yes, GO BLUE!
Old May 20, 2008 | 11:17 AM
mgoblue3's Avatar
mgoblue3
my apologies.......this bike is fuel injected!
Old May 20, 2008 | 03:00 PM
twincam47's Avatar
twincam47
check the throttle plate (butterfly) for missing screws and also see if your Throttle body is cracked where the throttle plate rod passes through on either side of the throttle body.....mag-marelli had a problem with this on some older bikes.
Old Dec 20, 2008 | 05:21 PM
jnickel's Avatar
jnickel
Also Check to make sure your plate isn't bent
Rusty Axle
Shovelhead
Apr 13, 2018 07:27 AM
2K1FLHPI
Oct 29, 2016 10:21 AM
LedBoots
Aug 29, 2014 05:33 PM
redhead356
Ironhead
Jul 14, 2013 09:36 PM
icehead2
Nov 3, 2011 09:25 PM
