headlight/electrical problem-need help
Old May 20, 2008 | 10:56 PM
mnbagger's Avatar
mnbagger
Default headlight/electrical problem-need help
Noticed my headlight was dimming then brightening tonight. I rode in the dark for probably a half hour and it was alternating dim/bright. My battery seems fine and is new this year. Any ideas? Thanks in advance.
Old May 20, 2008 | 10:59 PM
HawgriderPa's Avatar
HawgriderPa
Default RE: headlight/electrical problem-need help
you check your ground?
Old May 20, 2008 | 11:06 PM
mnbagger's Avatar
mnbagger
Not yet, but I will in the morning. I was on my way to work when this was happening.
Old May 20, 2008 | 11:07 PM
hogdoc's Avatar
hogdoc
Pull the headlight out and check the plug on the back. It is probably melted and frying the wires. When the connection gets loose it starts to overheat then melt the plastic and then the wires. You can get a new plug at the dealer prewired with shrink seal connectors on the wires!
Old May 20, 2008 | 11:09 PM
HawgriderPa
you didn't say how long the new battery was in place.. if it's fairly new, the connections to it may have worked loose..
next step would be as howgdoc suggests
does your volt meter show proper voltage?.. 14.5 while riding?
seandrew
Dec 16, 2013 09:00 PM
ff pie
Feb 20, 2010 10:09 PM
jjwin98
Mar 11, 2009 02:35 PM
CrewDawg
Electrical/Lighting/Alarm
Jan 31, 2009 07:29 PM
klf33
May 30, 2008 10:46 AM
