Oil top up
Old May 21, 2008 | 04:30 PM
Ian M's Avatar
Ian M
Default Oil top up
What amount of oil is needed to bring the level up to halfway from low when cold and on the jiffy stand on a 2008 Road King ?
Old May 21, 2008 | 04:35 PM
StankyWanky's Avatar
StankyWanky
Default RE: Oil top up
Oh hell, did kindergarden just let out? RTFM!!!!![sm=proof.gif] please turn your keys in to the nearest hd dealership.
Old May 21, 2008 | 05:21 PM
maxflhx's Avatar
maxflhx
I'll be a bit less harsh but say the same thing: your answer in in the owners manual. It's more than a beer coaster!
Old May 22, 2008 | 02:37 AM
Ian M's Avatar
Ian M
Come on chaps - I'm not quite that dense. My manual seems to concentrate on the actual topping up procedure, showing pictures of the dipstick levels etc i.e one for when the bikes on its stand and one for a side car (straight up). It just says top up halfway on a cold engine. I'm at work just now but I'll check the detailed stuff at the back of the manual to see whether it gives a figure - but I think it'll just say the total capacity rather than a top up level.
Old May 22, 2008 | 03:34 AM
Grizzled's Avatar
Grizzled
You should expect a dumb *** juvenile reply from someone who would buy one of those f**k'n ugly POS Night Trains.
Old May 22, 2008 | 06:29 AM
Jeff Dodson's Avatar
Jeff Dodson
You could have said something about the other two bikes, BUT I LIKE THE NIGHT TRAINS
Old May 22, 2008 | 06:50 AM
BadPiggy's Avatar
BadPiggy
Dude?
This is 1 assinine question, however...I feel compelled to help you out.
The correct amount of total oil capacity is 4 qts.
When changing oil there is usually 1/2 qt. left in the crankcase and other areas.
4 qts. - 1/2 qt. = 3 1/2 qts.
This is a simple item that ANY HD owner that wrenches on their bike SHOULD know!
Old May 22, 2008 | 11:24 AM
Ian M's Avatar
Ian M
Thanks for a helpful answer. I've read the manual again and as I thought it just mentions the total capacity, which as you say is 4 US quarts or 3.8 litres. All I wanted to know was what it requires to go from the lower level on the dipstick to the halfway level on the dipstick - i.e is it 1.75 US quarts (half of your figure 3.5 quarts) ?
Thanks again for your assistance
Old May 22, 2008 | 11:27 AM
Neckball's Avatar
Neckball
Not sure about the 08"s but on the older models if you fill it to the top when cold, you may be overfilled when hot. Follow the procedure in the owner's manual.
Old May 22, 2008 | 11:54 AM
Ian M's Avatar
Ian M
Yes, you're right - it's the same on 08s - that's why I only wanted to top up from the lower mark to halfway when cold.
