Riding Before Tuner is Installed
Old May 21, 2008 | 04:42 PM
Homebrew101's Avatar
Homebrew101
Default Riding Before Tuner is Installed
I have ordered air cleaner, slip-ons and am buying the SERT. My question is, to avoid dealer labor charges, I want to install the slip-ons and a/c then take it to the dealer for the SERT and dyno. Wil it run OK to do this? I only live about a 1/2 mile from the dealer so I could install the a/c right before I take it in and only have to ride it that far.
I know I can just install the slip-ons and ride it but will I do damage running it with the a/c on it for a 1/2 mile? The dealer wants $90 to install the a/c.
Old May 21, 2008 | 04:56 PM
StankyWanky's Avatar
StankyWanky
Default RE: Riding Before Tuner is Installed
you'll be fine, just bring a fire extinguisher just in case. It's covered under warranty if you toast it. [sm=badbadbad.gif]
hogbag07's Avatar
hogbag07
You won't damage the motor on a 1/2 mile ride.It will run a little lean and pop when backing off
Old May 21, 2008 | 05:01 PM
bucs012's Avatar
bucs012
You're good. Rode mine 40 miles to get done. It actually ran good.....
Old May 21, 2008 | 05:06 PM
drrandall1's Avatar
drrandall1
I ran my Fat Boy with Big Radius True Duals for 500 miles and all was fine with no fuel management. I installed the Fuel Pak just as a back up. It ran like crap. I took it out and ran for 5000 with no fuel management. Traded it in for my SG.
Old May 21, 2008 | 05:08 PM
XTrooper3936's Avatar
XTrooper3936
Just don't get too deep into the throttle or lug the motor and you'll be fine.
Old May 21, 2008 | 05:11 PM
tinker's Avatar
tinker
Your motor will run a bit lean and therefore hotter than the norm. Short distances should be no problem.
Old May 21, 2008 | 06:13 PM
frog13's Avatar
frog13
Yeah ...... like they all said, you'll be fine.
Old May 21, 2008 | 07:21 PM
pandol34's Avatar
pandol34
Save yourself some bucks...do it yourself. It will run a little lean, may even slightly discolor the pipes (but I doubt it).
Old May 21, 2008 | 07:24 PM
pandol34's Avatar
pandol34
Oh yea. Install the pipes also and be sure they don't leak (use Locktite High-temp (Gold tube) sealer)
