Oil Leak!!! 2000 FLHRCI
Old May 21, 2008 | 06:37 PM
dslwraith's Avatar
dslwraith
Default Oil Leak!!! 2000 FLHRCI
OK there is a small amount of oil that just appeared , it is coming from the left side from the bottom of the big case thing that is on that side, hey im not a mechanic
Shouldli be horribly concerned? Is something just loose? or mayeb a bad seal?
the bike had its 20k service done on the third of this month and all fluids were inspected and changed.
give me the non mechanic guy some helpful info before i go take it in.
it is very small amount leaking but i amnot sure how much is in there to begin with
Old May 21, 2008 | 06:47 PM
Beemervet's Avatar
Beemervet
Default RE: Oil Leak!!! 2000 FLHRCI
ummmm.....
Sounds like you have a leak from the primary cover, or the derby cover. Since you sound like you don't know a spanner from a wrench, take it back to the mechanic. It's no big deal.
Old May 21, 2008 | 06:58 PM
themensh's Avatar
themensh
The BIG cover on the left is your Primary cover. The round cover to the rear of the BIG cover is the Derby cover.
If the leak is only a drop or two when you ride it, no real biggy. If it leaks more than
a few drops whether you ride it or not......not a real biggy.
If you just had it serviced, stop by the mechanic and show concern.
He will probably just 're-torque' the fasteners.
Old May 21, 2008 | 07:02 PM
dawg's Avatar
dawg
Could be shift shaft seal???
Old May 21, 2008 | 07:04 PM
dslwraith's Avatar
dslwraith
i juts noticed it this morning and it was only a fe winches in diameter this morning and it is not eventhat big now since i cleaned the spot.
i was working on my shifter yesterday codl i have knocked osmehting loose when i too k it off and repositioned it ?
Old May 21, 2008 | 07:17 PM
dslwraith's Avatar
dslwraith
OK I am a dumb A$$ ,there is a screw missing on the big round cover ( the primary right ) and there is a small amoutn of oil leaking form there,
will i be ok until i canget a screw tomorrow??? or should i pick up some more oil too just to be safe?
Old May 21, 2008 | 07:20 PM
Beemervet's Avatar
Beemervet
Round cover......five bolts...........derby cover. Yes you will be ok.
Old May 21, 2008 | 07:37 PM
dslwraith's Avatar
dslwraith
ok just to be sure here is a pic
i think i need a bike jack hard ot take pics of that side of the bike lol
[IMG]local://upfiles/60419/29275707B7AA419BB99BA567999FC6F4.jpg[/IMG]
Old May 21, 2008 | 08:22 PM
TheBagger's Avatar
TheBagger
Go to your dealer and get a bolt. See your more of a mechanic then you think!
Jmyers1985
Jun 24, 2015 11:12 AM
jstorrusten
Aug 22, 2010 10:52 PM
spizzyman
Jun 8, 2009 12:48 AM
SpursDarkrider
Sep 10, 2008 11:05 PM
Tiggeresq
Apr 8, 2008 12:24 PM
