DYNO Numbers for Baggers???
Old Mar 8, 2010 | 07:46 AM
  #1661
troop's Avatar
troop
Default SE204"s
Originally Posted by RIDEINIT
07 Ultra Classic
Before 96"
Fuel Moto tuned slip ons
power commander III USB
Max Power 75.9
Max Torque 89.8
After 96"
V&H true duals
TTS Master tuner-custom map tuned
Screaming Eagle slip ons Dyno tuned "no longer quiet"
204 cams
30 tooth drive
Max Power 94.5
Max Torque 101.9 Torque comes on at 2.5 rpm and carrys to 4.8rpm above 100tq
costs a little to have done but I like it,2 up 90% -Way Cooler running
I'd really like to see some charts with the SE204 installed in a 103" bike at 10:1 cr. Bet it would be nice.....
Old Mar 9, 2010 | 05:36 PM
  #1662
mrdakotaman's Avatar
mrdakotaman
Default bub better than bassani??? i own bassani now need a bub
Old Mar 9, 2010 | 07:06 PM
  #1663
kstang71's Avatar
kstang71
WELL...... I skipped to the end of this thread just to add my two cents.. I couldn't tell you what the stock numbers were, probably somewhere near the way too slow range, but after spending 2k......... I am pretty happy with the results..
Old Mar 9, 2010 | 09:45 PM
  #1664
jmart963's Avatar
jmart963
2nd Gear
I am installing a 103 stroker kit.found one cheap.It is the 2003 cvo kit.I will post the dyno sheet as soon as I put 1000 mles on it.I kept my woods 6hg cams.Hope my numbers will be impessive.Any one need the 253 cams from the kit ?
Old Mar 10, 2010 | 06:16 AM
  #1665
Magnum_1340's Avatar
Magnum_1340
after my winter up grade, new 590 cam and stage3B head from J-Precision,
tune by Doc's new shop
106 S&S kit
110hp 116tq
Old Mar 10, 2010 | 08:13 PM
  #1666
flomastr's Avatar
flomastr
no cats bub 7 tdx. I also stand correctes it was 81hp/103tq. Lost alot if mph for water ever reason. No A/F on the bottom of the dyno sheet
Old Mar 11, 2010 | 10:30 AM
  #1667
devastationinc's Avatar
devastationinc
Stage II
Question 2009 FLHX 103 Dyno
Thoughts?
Attached Thumbnails  DYNO Numbers for Baggers???-img00077-20100311-1014.jpg    DYNO Numbers for Baggers???-dyno-chart.jpg
Old Mar 11, 2010 | 01:00 PM
  #1668
Bavarian_Custom's Avatar
Bavarian_Custom
Hi Guys,
here is a fresh Dyno Sheet from a 107 Ultima Engine, but it is the EPA Version not the Competition.
Like you can see it is a radical difference to the 115HP and the 120 Lb ft
The Epa Version comes up with 76 HP and 100 Lb ft on the Rearwheel
Old Mar 13, 2010 | 09:38 AM
  #1669
bigdwh03's Avatar
bigdwh03
6th Gear
Default 204 cams?
Anyone have a Dyno sheet with a 103 with 204 cams.
Thanks
Old Mar 14, 2010 | 05:05 PM
  #1670
Beak's Avatar
Beak
2010 SEUC 110
Rinehart True Duals
Stage 1 A/C
Sert
Dealer installed new, first sheet is with SERT. Had a problem between 2000-2400 rpms. Tech sad they could not tune below 15% throttle, which is where that rpms was in 6th gear. At no cost to me, replaced the SERT with a Power Commander that is the second sheet.
Attached Thumbnails  DYNO Numbers for Baggers???-img_2530-1.jpg    DYNO Numbers for Baggers???-img_2532.jpg
