DYNO Numbers for Baggers???
Old Jan 17, 2011 | 09:37 AM
  #2141
itsaw0rkinpr0gre$$'s Avatar
itsaw0rkinpr0gre$$
"Seeker of Freedom"
Originally Posted by 120 GLIDE
2010 roadglide 120r motor thunder header 58 mm throttle body.135.6tq 130.9 hp to the wheel
Got any video's with the thunderheader and can you post up the dyno sheet? Is this a crate or kit?
Old Jan 17, 2011 | 09:56 AM
  #2142
Joker65's Avatar
Joker65
Originally Posted by marines267
2010 Electra Glide Ultra Classic
SE AC stage 1 kit
SE tuner
V&H big radius 2 into 2
78 hp
86 tq
i had the same set up on a 2008 ultra and i had 80 hp and 85 tq
I'd call that "identical".... except now you've got the improved frame.
A simple cam-swap and tune would put you up around 88 Hp / 98 Tq.
Still a nice ride, just the same!
Old Jan 20, 2011 | 07:26 AM
  #2143
CigarCritic's Avatar
CigarCritic
Default Fuel Moto 107 - No Head Work
Fuel Moto 107" - No Head Work
220 miles on Autotune
Attached Thumbnails  DYNO Numbers for Baggers???-107sae.jpg    DYNO Numbers for Baggers???-107uncorrected.jpg
Old Jan 20, 2011 | 09:05 AM
  #2144
Lucky1958's Avatar
Lucky1958
Default cams
So I read all these posts and looked at all the charts.
My bike is in pieces at the shop and they are installing my cams.
I started with pipes,SE tuner,stage1 aircleaner. TC96
The dyno run with that was HP 75 TQ 85
I am doing the SE-255 I dont want a bunch at 5K and above I want ride ability and better roll on at highway speeds.
Im jealous of the rockin numbers posted here and the guys that have installed 120R's in the bikes.
I came off sport bikes and miss the instant power and speed.
There has been some really great info here that helped me make my decision.
Thanks
Old Jan 20, 2011 | 02:27 PM
  #2145
GREENOHAWK69's Avatar
GREENOHAWK69
Originally Posted by Unbalanced
2002 Police Road King 147 tq/143 hp built by Cycle Rama
62 mm HPI with A/C, 6.22 injectors, Rinehart True duals, 6 speed, Scorpion Clutch, 640 cam, AIM VP92-T, SERT, Paint by Metal Mafia
2004 SEEG 117tq/115 hp HPI 53mm 4.35 injectors, CNC Heads by Redmond, Yuill Brothers YB13 cam, Rinehart True Duals, Zippers Adjustables, Zippers A/C, SERT
2005 SEEG 142 tq/135 hp HPI 58mm with A/C, 6.22 injectors, Kuryakyn 546, Aim VP92-T, Rinehart True Duals tuned by doc with TTS
Curious to know what your MPG are with these bikes?
Old Jan 20, 2011 | 03:15 PM
  #2146
Unbalanced's Avatar
Unbalanced
Greenohawk,
2002 ~ The S&S gets 38/40 if I ride sensibly, hard riding ends up around 32/33 Best mileage is at 75/80 on highway
2004 ~ The HD gets 39-42 riding hard 34/35
2005 ~ The Jim's 38/40 riding hard 31/32
My mileage does vary quite a bit, as I am easily instagated into playing
Old Jan 21, 2011 | 07:30 AM
  #2147
Lucky1958's Avatar
Lucky1958
Default Dyno run
Stoped by the shop on the way home yesterday.
first run had HP at 83 and torque just under 100 with a pre made map.
fuel to air was about 13-1
He said it would take a couple runs to optimize it.
Final numbers wer 84/100
It sounds like a different animal cant wait to get it this afternoon and she what it feels like on the but dyno
Old Jan 21, 2011 | 03:35 PM
  #2148
Samzilla's Avatar
Samzilla
Talking 2009 Ultra Classic Dyno Numbers
Here are the numbers on my 2009 96" HD Ultra Classic. No head work was done. Just the following "bolt on" modifications.
Exhaust is 2009 Bub 7 Stealth TDX True Duals
Cycle-Rama High Intensity 575 Cams
Kuryakyn H-Five Mach 2 Air Cleaner
TTS Master Tuner
Horsepower = 91.5
Torque = 99.5
Old Jan 22, 2011 | 03:27 PM
  #2149
Eric in chicago's Avatar
Eric in chicago
120R crate "plus" motor
Detail of build/parts in signature below.
Monster Torque Build
130hp/144tq (uncorrected)
Attached Thumbnails  DYNO Numbers for Baggers???-120-uncorrected-dyno.jpg    DYNO Numbers for Baggers???-sae-dyno.jpg    DYNO Numbers for Baggers???-120r-std.jpg
Old Jan 23, 2011 | 03:56 PM
  #2150
Stoood's Avatar
Stoood
TTS Master Tuner
Horsepower = 91.5
Torque = 99.5
How's the Torque at 2500 RPM and just slightly below? Is it smooth if you roll it on from 2000 up (not recommended, but will it do it in 6th?). Does it pull hard above 4000 RPM, or just seem to "run out of wind" ? I would love to see a Dyno when available.
-Very impressive for a stock 96. Wes at CycleRama has his act together!
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
