2011 FLHTK 103 S/E A/C V&H Dresser Dauls Rinehart 3 1/2" slipons SERT MAX HP= 75.97 MAX Torque = 93.43 Stock was MAX HP= 61.51 MAX Torque = 77.26 Thinking of going with SE 255 cams
We could do with a dyno man to explain how they can come out like that!
It's a simple explanation, the HP is "scaled" differn't than the TRQ. If you look at a "normal" print out, you'll see that both the left and the right sides have the same top number, in this attatchment they are both 140, the left side (HP) top is 140 HP and the right side (TRQ) is 140 TRQ. In 2008RKC08's his hp is scaled differntly than his TRQ, Hp maxes out at 90 and trq maxes out at 110. Since the scale is differnt they don't cross at 5250RPM's like you are used to seeing. There is nothing wrong with the printout and the operator wasn't doing anything shady. I agree it doesn't look normal and pringing this way is confusing, but it is accurate.
harleytuner,
Thanks for the explanation and thanks to davewear & grbrown for responding too! I learned something new today.
Love my 255's was going to install the woods 555 but wanted the power in the area i ride in HP=84 torque =100
2002 Electra Glide Standard-Carb.
Wiseco 1550
SE rods
SE intake
Mikuni 42mm
Dyna Tech ignition
590 cams
Stage III heads
Klockwerks 2 into 1 exhaust(by Bub)
up to 9 dynos since build now. Looks like it will pry finish 109/109 consistantly
109.+ HP 108.+TQ on this chart
