DYNO Numbers for Baggers???
Old Feb 13, 2011 | 07:21 PM
  #2231
cowboy Harry's Avatar
cowboy Harry
2010 Ultra Glide. 103 cu in. SE 255 cam. Fuel Moto Header. SE Street performance mufflers. SE race tuner. bout 88 hp & 101 tork.
Old Feb 14, 2011 | 06:07 AM
  #2232
one78shovel's Avatar
one78shovel
Originally Posted by harleytuner
Looks like you're running to lean for wide open throttle. Would be better at 13.0:1 on the airfuel.
Thanks- I have other DYNO sheets from previous years ran at 13.0:1 with not as good numbers. Then again, seems there is the chance these current numbers are inflated? Had the run at Bartel's in LA.
The bike does run very smooth however.
-178S
Old Feb 14, 2011 | 08:04 PM
  #2233
producer's Avatar
producer
Hey your run looks good! Which TC HD dealership did this; N or S ? Like I said in ealier post, I've only seen one other 103 look this good. Not sure if he had as high of HP numbers.
Take a look at 2008RKC08 96" with SE255's. His HP/TQ crossing point is at 4300; rougly. It should show it at 5250; roughly. This run is a being misrepresented (A Lie) or the dyno jockey doesn't have the software set up correctly.
Originally Posted by harleyiron80
08 flhtp
v h slash cut
se race tuner
se 255
arlen ness ac
Old Feb 14, 2011 | 08:31 PM
  #2234
harleyiron80's Avatar
harleyiron80
south not too far south i checked out a few runs and i see most cross at 5252 thats a bit of info to know i think the # coming out of the dealership could be a little high it makes for good conversation during the winter months
Old Feb 14, 2011 | 08:34 PM
  #2235
harleyiron80
Default a-c
what a-c are you running
Old Feb 15, 2011 | 06:37 AM
  #2236
Joker65's Avatar
Joker65
Originally Posted by eliminator28
here is mine Attachment 166357
Yeah... that's gonna keep you grinnin' for awhile!!! Nice build!
Old Feb 15, 2011 | 11:39 AM
  #2237
davewear's Avatar
davewear
there's nothing wrong with that chart it's just printed out using different axis. you'll notice the torque numbers come from the right side and the hp from the left.
also good numbers as it is a 4 th gear run.
Old Feb 15, 2011 | 12:30 PM
  #2238
grbrown's Avatar
grbrown
Unhappy
I agree with producer, there is something wrong with that graph. The curves start and finish together, but it isn't possible to believe the numbers the way the graph is currently printed. If it was mine I would ask the dyno guy to explain and print off a correct one.
Old Feb 15, 2011 | 12:58 PM
  #2239
davewear's Avatar
davewear
Ya i don't know why some tuners print out this way but the numbers aren't off, 97 ft/lbs and 83 hp are pretty typical for a 96 with 255's.......
Old Feb 15, 2011 | 01:21 PM
  #2240
grbrown's Avatar
grbrown
Thumbs up
We could do with a dyno man to explain how they can come out like that!
