DYNO Numbers for Baggers???
Old Oct 2, 2011 | 09:54 PM
  #2741
coolerman69's Avatar
coolerman69
LOL!!!
  #2742
terryrh's Avatar
terryrh
So what you're saying is that I can't go 120mph?
Old Oct 2, 2011 | 10:00 PM
  #2743
coolerman69
Originally Posted by Heatwave
Absolutely no way you're shifting from 4th to 5th at 120mph. Not happening today or tomorrow. In fact I highly doubt that that engine with stock gearing could even touch 120mph. Unless you've had some serious headwork to go with that cam, the parts and exhaust you have on the bike probably aren't even generating 100hp out of that 96" motor. Have you had it dynoed? Unless that engine's cranking out 110+hp, changed the ratio of the stock tranny and the build peaks over 5800rpms, then there's no way on God's green earth that you're doing 120mph in 4th 5th or 6th gear. Setting the redline at 6400 is simply irrelevant if your peak hp was below 5500rpm which it would be with that cam and exhaust. What you've described is the most basic of engine upgrades and would barely take your stock 96" from its base hp of around 68-70 hp into the low 90hp assuming it had an excellent tune on a happy dyno.
I have an 88ci with stock heads that will do 120! Wanna see a video?
Old Oct 2, 2011 | 10:18 PM
  #2744
Heatwave's Avatar
Heatwave
Member
I don't mean to p*ss on anyone's parade but a stock 2008 softail with a 96" that has a cam, exhaust, tune and stock gearing just isn't going to do 120 without a really long downhill run and a nice tailwind.
Old Oct 2, 2011 | 10:19 PM
  #2745
Heatwave's Avatar
Heatwave
Member
Sure...why not?
Old Oct 2, 2011 | 10:21 PM
  #2746
terryrh's Avatar
terryrh
Noted.
Old Oct 2, 2011 | 10:24 PM
  #2747
coolerman69
Sure...why not?
Ok stay tuned!
Old Oct 2, 2011 | 10:37 PM
  #2748
TX_Bagger's Avatar
TX_Bagger
6th Gear
Originally Posted by FL_HIGHLANDER
I'd sure like to see the dyno sheet on this one. Hmmmm
I've got the dyno sheet scanned, but I'm not sure how to upload an image on this forum. The "insert image" icon only allows be to point to a website. I have the image on my computer.
Old Oct 2, 2011 | 10:39 PM
  #2749
Heatwave's Avatar
Heatwave
Member
Ok stay tuned!
Looking forward but please don't take any unneccessary risks if you don't already have the video. Once again, that 88ci with stock heads is probably making about 65hp. I assume its a 5sp. The gearing of that bike combined with the power of the 88 with stock heads just won't develop enough hp to push that sled to 120mph.
I had an 88 (2003 fatboy) before my current bike. I had it punched to 95", headwork, SE 258 cam, roller rockers, forged pistons, tuned and upgraded exhaust. She ran great. Produced 101hp and 103ftlbs and with the 258cam was designed to run at much higher rpms than most guys like to ride at. In upstate NH I ran wide open against my buddy's Valkyrie which is a formidable 6cyl Jap cruiser. We left the throttles wide open heading south on 93. I walked away from him at 127 (gps since the stock speedo only goes to 120) before I shut it down. I figure maybe it had a mile or 2 more in the throttle. I weigh more than most guys since I'm 6'4" and about 260 so maybe the bike would have alittle more top end with a regular sized guy.
Trust me, a stock 88, with stock heads and pistons and stock exhaust is going to die long before it hits 5000rpms. No way it makes it to 120mph with stock gearing and stock sprockets. Top end is probably between 110-115. The next 5mph takes alot more hp to push the very un-aerodynamic HD past 120.
Old Oct 2, 2011 | 10:42 PM
  #2750
TX_Bagger's Avatar
TX_Bagger
6th Gear
Originally Posted by Deuuuce
Curious, was that in the Texas heat?
Yes, it was done in late July or early August. I'd have to go find my receipt because it doesn't seem to be on my dyno sheet.
