DYNO Numbers for Baggers???
Old Oct 3, 2011 | 12:35 PM
  #2761
Heatwave's Avatar
Heatwave
Member
Originally Posted by coolerman69
Fertilizer huh? Tell ya what. Ride on over and we'll line up your over priced, look what i can afford 110, against my little 95ci EG and you'll get to taste some of that fertilizer when you eat your words! 1/8, 1/4, 1/2 or a mile anyway you want it!
LOL...mine's bigger than yours
Old Oct 3, 2011 | 12:39 PM
  #2762
Heatwave's Avatar
Heatwave
Member
Originally Posted by harleytuner
I've been 120 plenty on bikes with stock bore and gearing. A good set of cams and a good tune will get you there. The 5 speed bikes are geared better than the 6 speeds as well.
What stock bike might that be and with what cam? Still not buying it. Sorry but these bikes just don't crack 120 because you change the cam and exhaust. Just not enough HP. Now if you're including headwork, then it becomes doable.
Old Oct 3, 2011 | 01:24 PM
  #2763
bowtie98607's Avatar
bowtie98607
6th Gear
Hey coolerman they say up to 12HP. Obviously it didnt work out that way for me. (
Old Oct 3, 2011 | 02:16 PM
  #2764
Heatwave's Avatar
Heatwave
Member
Let me see if I have this right.... you have a 2006 Electraglide with 82hp & 94 ftlbs and a 203 cam that dies at 4500rpms riding on an 85 rear tire (about the size of my son's bicycle tire) and you want to race a guy that been riding for 40 years and has a 2010 SE Ultra/SG with 115hp & 119ftlbs combined with an SE clutch, Hillside headwork, Woods 408-6 cam, a 180 rear tire and peak hp at 6k? Did I get that right?
Either you struggled in high school math or you REALLY enjoy looking at LED tailights
Old Oct 3, 2011 | 02:52 PM
  #2765
harleytuner's Avatar
harleytuner
My wifew Dyna LowRider will do it, easily. Not all cams fall of at 4000 RPM's. I bury her speedo every single time I ride her bike. 96", V&H straight shots, SE 211 cams, SE stage I a/c, SERT tuned by me. Here's her sheet. And when I had the 211's in my bike with the stock bore, heads, I could hit 120 as well. I've been 146 on it now with it's current set up and had a little throttle left. My brothers '05 road king with airbox and hooker slip ons has been to 112 with a GPS. Speedo read higher, but the GPS hit 112.
Old Oct 3, 2011 | 03:22 PM
  #2766
Heatwave's Avatar
Heatwave
Member
That dyno and the 95 hp peak at 6k, I would say it's possible on a lightweight Dyna to hit 120 but I still doubt it's able to hit 120 unless you're getting that speed off a GPS. My guess is at 120 on the bike's speedo you're probably 4-5mph "happy".
Where's the dyno of the bike that's running 146? My guess is that you'll need close to or over 120hp to hit 146mph on a Dyna. Maybe even 130hp.
The 112 on a stock RK sounds about right.
Old Oct 3, 2011 | 04:10 PM
  #2767
harleytuner
I didn't have a GPS on my wifes, just going off the speedo, but it was burried. I suppose I can put a GPS on it but I don't see the point as I have no dog in this fight and nothing to prove. As far as my bike goes, yes I am over 120 HP, and yes you are correct, the speedo is happy by around 4 MPH, I hit 146 with a Garmin GPS mounted on my handlebars, so i wasn't going by the speedo. The nice thing about the GPS is that it hold the top speed for you, so it was after I parked it that I saw I hit 146, had I been watching it while I was riding I would've pushed it to 150 since I had more left in it. I don't have a current dyno sheet on this computer of my bike, but I have one of what it was before I changed the cams again. It was 129 HP and 121 TRQ, but, like I said, that was the previous build.
Old Oct 3, 2011 | 04:17 PM
  #2768
terryrh's Avatar
terryrh
That's kinda why I just left it alone. I know what I saw, buried needle and still climbing. I'm sure it was in a dream though.
Old Oct 3, 2011 | 05:11 PM
  #2769
Heatwave's Avatar
Heatwave
Member
Now that definitely makes sense. With 129hp on a light bike like a dyna, you should be capable of the speeds you're talking about. Now whether the Dyna's frame, wheels, tires and wheel bearings are able to handle those speeds is an entirely different question but that kind of hp should definitely push a light sled like a dyno to those speeds.
Now for the other poster that thinks he's hitting 120mph on his speedo with maybe 70 hp on a heavier sled like a softail classic with a shield and bags...well .....that does sound like a dream and one of those dreams that has a "happy ending"
Old Oct 3, 2011 | 05:37 PM
  #2770
harleytuner
The Dyna makes 95 HP and 95 TRQ, it's sheet is in my other post, the comparison on that sheet was when she was a 96" stage I to the cams. My bike (129 HP) is a 110" electra Glide Classic. Both bikes will go well over 120 MPH. My E.G. is the one that I have been to 146 MPH (with a GPS) and her bike (Lowrider) I have had burried (off the speedo, not GPS). The only reason I brought her bike (Lowrider) into this conversation is because you said that a stock bore bike with stock heads cannot reach 120, I have to disagree with that. With the right cams and a good tune they can. I even used my brother 05 Roadking that is a stock bore 88" without cams, he topped out at 112 MPH (with a GPS), I have no doubt at all that with good cams his bike could hit 120 MPH.
