DYNO Numbers for Baggers???
Still a rockin 2000 95" not much done to the heads just H/D springs port and polished.
cams gear driven
cam plate
High volume oil pump
11 to 1 comp.
48 mikuni
slash cut cycle shack pipes it loud very loud but fast very fast!!!!!
It is pumpin 118 HP 121TQ
cams gear driven
cam plate
11 to 1 comp.
48 mikuni
SE 211 or SE 255, or go with Andrews 26? I have a lot of questions as this is my fisrt Harley in 67 years. My retirement present to myself.
cams gear driven
cam plate
11 to 1 comp.
48 mikuni
As far as the SE cams, I'd consider either the 204 or 255. With the 211, you'd be giving up performance in the lower rpm range. Really, the 211 needs more compression to work well. Lots of guys love the 204. It works pretty well in the low end, and rocks in the mid-upper range. It also has the benefit of a great sounding idle. It's probably about comparable to the stock cam until around 2500 rpms, then it would take off. The 255 is a favorite of touring bike owners because it shines in the rpm range most of us ride... 1800 to about 4000.
I haven't worked with the Andrews cams, but there's lots of guys here that have. Just looking at the timing events, the 26 looks similar to the 204, but with a little less lift, duration, and overlap. It would probably come on a little earlier than the SE204, and the 204 would probably hold on a little longer. That's just an educated guess, not based on actual experiencee.
Really, for anyone to advise you on cams, you need to identify what rpm band you tend to ride in, and what you're wanting to accomplish. Do tend to ride at 3000 plus rpm, and like to bounce off the rev limiter? Do you want stop light to stop light performance? Do you tour 2-up, fully loaded? What I like might not be what you like.
But as boogaloo stated it depends on what your after.
The best advice I can give is to be sure and use a good map builder / tuner.
Stage II 103 kit w/ SE 255 Cams
SE Pro super tuner
D&D Boss Fatcat with wrapped performance baffle
SE stage I air cleaner with Zippers' filter upgrade
Bike stock 68 hp and 84 tq
Bike now 92 hp and 106 tq
This sounds like what I need as I pack double most of the time and just cruise the highways. I gave up riding it hard a few years ago ( maybe 30 years ago)
Again thanks for the input.
