DYNO Numbers for Baggers???
Old Jul 21, 2019 | 07:47 PM
  #5871
GEORGEW's Avatar
GEORGEW
Originally Posted by GSA_KEV
2012 Road Glide - Thundermax Tuner, Rush True Duals, bored to 107 with forged 10.5:1 pistons, 580 cams, CNC heads with 1.9 intakes/1.615 exhaust, AIM Clutch
My 103 with Cyclerama Cams & Headwork is a lot like your 107.
Old Jul 23, 2019 | 04:46 PM
  #5872
jptfst66's Avatar
jptfst66
Default Jackpot 2 into 1
107 fuel Moto
Hillside Stage 2 heads
Screaming Eagle forged crank welded, trued, plugged and balanced with pistons. Left side bearing
Jackpot 2-1 exhaust
1st pull was with Rhine hart
2nd pull FM Jackpot 2 into 1
111hp 120 torque.
A blast to ride.
Old Jul 24, 2019 | 11:56 AM
  #5873
lightweight bob's Avatar
lightweight bob
Default Mid-range torque.
Originally Posted by jptfst66
107 fuel Moto
Jackpot 2-1 exhaust
111hp 120 torque.
A blast to ride.
To quote Smokey Yunick, one of the most famous Nascar engine builders, "Giving up mid-range torque for top end horsepower on a
street driven vehicle is a loser everytime." Your dyno chart is a great demonstration of those words.
Old Aug 18, 2019 | 06:16 PM
  #5874
ramdaspadhye's Avatar
ramdaspadhye
117" @ 10.8, branch heads, hpi 62mm tb, redshift 657, supertrapp supermeg
Conservative tune to ride anywhere. Ambient temp during dyno was 95 degrees
Old Aug 18, 2019 | 08:38 PM
  #5875
GEORGEW's Avatar
GEORGEW
How many disc used with the Supertrapp and open or closed endcap?
Old Aug 19, 2019 | 03:53 PM
  #5876
ramdaspadhye
12 disc, open endcap
Old Aug 20, 2019 | 01:37 PM
  #5877
lightweight bob
Default Nice dyno work
Your dyno shop really did a nice job of smoothing out your torque curve 2500 to 3000 rpm - about 40 ft lbs more where you can really use it.
Name / location of the shop? Tnx in advance.
Old Aug 21, 2019 | 02:51 PM
  #5878
ramdaspadhye
Happy trails motorcycle connection
Fayetteville Arkansas
Call and talk to Bill
My only concern is he tuned the ve tables with tps vs map.
Old Aug 22, 2019 | 06:42 AM
  #5879
harleytuner's Avatar
harleytuner
What would that concern you? What year is your bike?
Old Aug 23, 2019 | 06:47 AM
  #5880
ramdaspadhye
15 road glide. Ve tables with map vs tps usually do better due to change in load not just a predetermined value for tps. Sometimes map/tps are not in sync.
