What just happened
I have an 08 RKC and I know about the throttle issue. I always have the throttle down when I shut the bike off. I was riding today and all was fine. I came to a red light on a hill so I held my position with the clutch and a little throttle.
When you're stopped, throttle's at idle, clutch is disengaged, and the brakes do the work.
The rest of your post was incomprehensible.
If any of the above doesn't make sense to you, just get help.
in the TBW and blame the problems on owner operator. It doesn't matter how you
hold the bike on a hill, throttle sticking shouldn't be happening.
Tell your Dealer to fix it.
I frequently use throttle/clutch to hold position, no need to worry about rolling back on some *** such as you appear to be, crowding my bumper when getting off the brake onto the gas.
Well, sir, I'm going to just say it straight out - if you have to stop *any* kind of vehicle "on a hill", you don't "hold your position" with your clutch and throttle. I don't give a damn what it is - you use BRAKES to stay put. That's it. What about that don't you understand?
also, your post suggests that you would be in neutral while stopped (throttle's at idle, clutch is disengaged) which in itself is wrong. if someone comes up behind you and is not stopping, then you will be wasting precious time trying to shift into first so you can scoot butt out of there.
to the op, hope the dealer can find something wrong to fix. sucks when you have something happen and the dealer can't find/recreate the problem and sends you on your way.
