Cooling fan installation?
Old Feb 28, 2006 | 12:02 PM
msbhvn's Avatar
msbhvn
Default Cooling fan installation?
Is the fan thermostat controlled or controlled with an on/off switch. If it utilizes a switch did you use the acc swich on the fairing? How involved is the installation?
Old Feb 28, 2006 | 05:20 PM
nuke_mech701's Avatar
nuke_mech701
Default RE: Cooling fan installation?
I bought a used Road King Police bike that had the cooling fan. The fan is controlled by a thermostat. It kicks at some temperature that is monitored somewhere. The horn gets relocated on the front tab of the gas tank. It works pretty good especially on the Interstate parking lots. Leg gets warm for sure when the fan kicks on. When I got the bike, I noticed the one of the rubber bushings didn't match up with the others, it was more of a grommet instead of a bushing. You probably could hook it up to bypass the thermostat to provide cooling whenever you want. Sorry I couldn't really fully answer your question.
Later
Bob Tompkins
Old Feb 28, 2006 | 07:49 PM
roadglidin's Avatar
roadglidin
I have one on my RG. Im assuming you have RK (accessories switch) Bob is 100% correct, thermostat controlled. The "stat" is located on the air cleaner backing plate closest side to the motor. Now mine in an '06 model, and I understand that there had been a "problem" some years back, that the fankit hardware would shake loose. Good news is that hardware has been upgraded and the problem gone. One of the brackets is connected down to a bolt closest to the stator plug.
Relocating the horn was the most involved part of a RG installation due to removal of the fairing. Hope this helps. TOM
Old Feb 28, 2006 | 07:57 PM
2005UltraNC's Avatar
2005UltraNC
Put one on my Ultra Classic - before I really read more on this forum that the TC88's are setup really lean and thus a cause for some of the heat. I'm doing the Stage 1 and pipes and SERT and hope this helps with the heat as well.
But an average wrench will probably need two hours to put in the fan kit.
ACC is not used, theromstat and power to the B+ lead, kit comes with a relay and all wiring.
If you do it, have fun.
Bruce
Mchad
Jan 1, 2017 12:10 PM
Thor
Electrical/Lighting/Alarm
Apr 24, 2016 05:31 AM
jdvorchak
Jan 10, 2015 02:02 PM
wildwillie2u
General Topics/Tech Tips
Aug 30, 2007 05:16 AM
jnetmac
Apr 10, 2007 10:00 PM
