help with front wheel install
Old May 30, 2008 | 06:41 AM
motion's Avatar
motion
3rd Gear
Default help with front wheel install
Help! I'm installing the front wheel on my 99 flht and can't seem to remember which spacers go where. It seems as though the speedo drive is the left hand spacer and then i have two spacers
left. One longer than the other. The long one seems to go on the right side and that gives the correct spacing for the brake caliper. But when i assemble the thing that way it seems that there is still a spacing issue. Is there room someplace for the shorter spacer or am i missing the correct way to tighten the axle nut and draw it all together?????
Old May 30, 2008 | 07:19 AM
dawg's Avatar
dawg
Default RE: help with front wheel install
Might this help? Click on the "x" and it will open
[IMG]local://upfiles/13641/1829FD53A7604CBEB34757576908FDE6.jpg[/IMG]
Old May 30, 2008 | 07:28 AM
motion's Avatar
motion
3rd Gear
i'll try it that way. but it seems like it needs the long one on the right side to space the wheel correctly. Thank you!!
Old May 30, 2008 | 07:31 AM
motion's Avatar
motion
3rd Gear
i noticed that the exploded diagram was for sealed bearing models. Is it the same for tapered bearings like the ones in my 99?
HD-Heaven
Aug 22, 2018 07:56 AM
boogyman1313
Nov 14, 2013 10:31 AM
rpmp3
May 11, 2008 09:09 PM
cHarley
Nov 22, 2007 04:33 PM
03RKC
Apr 5, 2007 09:01 PM
