Is 91octane really needed
Old May 30, 2008 | 09:15 PM
winston chopper's Avatar
winston chopper
Default RE: Is 91octane really needed
Sorry Milo, I have not seen a thread about this yet. EXCUSE ME for being so ignorant .With all your vast knowedge from your 124 posts I should have asked you directly . I just asked for an opinion.Why else would I care other than the 20 cents.
Old May 30, 2008 | 09:18 PM
winston chopper
Waht exactly is pining?
Old May 30, 2008 | 09:29 PM
Iowabiker's Avatar
Iowabiker
Good for you Winston Chopper. It seems there are too many guys on this site that think they have all the answers like Milo. I enjoy a good discussion and enjoy learning. There are no stupid questions, just Milo type responses.
Old May 30, 2008 | 09:37 PM
Rush0608's Avatar
Rush0608
ORIGINAL: winston chopper
Pinging is pre-detonation of the fuel. The higher octane rating signifies the temperature at which the fuel in the cylinder combusts. If you run an octane less than required, the fuel will combust prematurely while the piston is still on its upstroke causing a pinging sound. Not good for an engine.
Old May 30, 2008 | 09:45 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
ping is preignition detonation sounds like a man with a little hammer is in the top end bangging away when the motor is hot and under a load.its also called deiseling it can sound like a deisele engine. the fuel charge ignites b4 the plug sparks and gives an uneven burn in the chamber it ussually causes the top edge of pistons to pit and if left unchecked the ring grooves will get ate up. higher compreson requires higher octane(wich is less explosive).the 96 inch motor seems to have the timing advanced pretty far (for cleaner hotter burn epa) so running higher octain is a good idea but if u remap and retard timing(most tuners will retard the advance curve a bit) u get less ping and a litle less preformance and could get away with lower octane unless its really hot or under a heavy load.
Old May 30, 2008 | 09:50 PM
winston chopper
Thanks for the ping lesson! Appreciate all the replys guys. Be safe!!!
Old May 30, 2008 | 09:52 PM
MrHd1's Avatar
MrHd1
Good question actually. For one there areplaces where 91 or better aren't sold oreven 89 is 10% ethanol. Last Sunday I rode in aFiremens Memorial Ride (2005 FLST 95" V&H FP) and when bike got really hot I noticed some slight pinging with the 93 I had in it. I've run 89 when it was cool and had no problem. I've experimented because I want to know what I can reasonably do in a pinch. Bottom line is these are air cooled motors and operating temps. vary widely. The factory recommendation is meant to cover all the bases.
But wait, there's a whole other issue and maybe even more important: I've yet to pull apart one of these motors (TCs and Evos) that didn't have significant carbon deposits on the piston crowns, For those that may not know themore carbon the more likely you'll have pinging. THis is for 2 main reasons. One the buildup raises compression and two the carbon is alot like charcoal and retains heat contributing further to pre-ignition (pinging).
Perhaps some suggestion regarding how to prevent this build upsuch as certain types of fuel or additives, or lubricants would better serve the subject. Just my .02.
Old May 30, 2008 | 10:11 PM
davewear's Avatar
davewear
if you type "octane" into the search you will get hours of reading and lots of good info. generally there is no benefit to running higher octane than what your bike requires. if you get no pinging and the bike runs good on 87/89 then that's what you should run.
Old May 30, 2008 | 10:37 PM
leohd's Avatar
leohd
most pumps use the same hose with 3 selections so your 1st gallon is probably what the last person used anyway.
Old May 30, 2008 | 11:05 PM
marc52454's Avatar
marc52454
isn't there a difference between preignition an detonation?
