HD turn,run,brake module for FLHX?
Old Jun 5, 2008 | 10:42 PM
grimminator's Avatar
grimminator
Default HD turn,run,brake module for FLHX?
&nbsp\\;I put the kuryakyn LED tail light on but in the sunlight it does not seem to be that bright. Decided on installing the turn, run, brake module but after looking at the description on the HD&nbsp\\;part which says"will not work on short directional bar", Im wondering if it will work with the VERY short directional bar on the street glide. Does the module fit in or by the light bar?&nbsp\\;Also what do you think about the&nbsp\\; kuryakyn unit,I know it has the pulse brake feature,thanks in advance!
Old Jun 5, 2008 | 11:07 PM
BlackBagger's Avatar
BlackBagger
Default RE: HD turn,run,brake module for FLHX?
I have the Kuryakyn Panacea setup that flashes before solid braking, also does a field of amber for turn signals, bright and noticeable. I also switched out the lower three bar light to act as a brake also on the SG.
Old Jun 5, 2008 | 11:21 PM
Harleypingman's Avatar
Harleypingman
The HD run/brake/turn module you want is PN 69462-06A\\; simple plug and play using the connectors under your seat.
Old Jun 6, 2008 | 12:51 AM
White Knight 04's Avatar
White Knight 04
It works with this many lights on the back of an Ultra....
Old Jun 6, 2008 | 06:03 AM
cig's Avatar
cig
The H-D module will work. They only say that because some states laws say the lights have to be so far apart to be red. Never heard of anyone being stoped for it.
Old Jun 6, 2008 | 06:57 AM
HRLYSG's Avatar
HRLYSG
Is there a link to that module online (couldn't find it) or is it in the H-D "big book?"
Old Jun 6, 2008 | 09:07 AM
Harleypingman
ORIGINAL: NoBike58
&nbsp\\;
Page 373.&nbsp\\; It should also be found at the HD website.
Old Jun 6, 2008 | 10:27 AM
BIGSKY_FLHXI's Avatar
BIGSKY_FLHXI
I have the same setup.. LEDs all the way around but I don't get the "not&nbsp\\;that bright"&nbsp\\; Mine are great. The Kuryakyn module is awesome.&nbsp\\; Flashes three times then steady.&nbsp\\; make sure you change the turn signal lenses to red.
Old Jun 6, 2008 | 11:01 AM
HRLYSG's Avatar
HRLYSG
ORIGINAL: Harleypingman
Page 373.&nbsp\\;It should also be found at the HD website.
&nbsp\\;
Thanks!
Old Jun 6, 2008 | 11:39 AM
Harleypingman
You're welcome.
