Cruise Light Stays on!!! Help...
Old Jun 6, 2008 | 08:09 PM
jcbpa's Avatar
jcbpa
Default Cruise Light Stays on!!! Help...
Hard to believe....&nbsp\\; Cruise light stays on... I can set it no problem, but cannot shut it off with the on off button.&nbsp\\; It shuts down if I tap the brakes or roll the throttle back, but the orange light stays lit 100% of the time.
Old Jun 6, 2008 | 09:41 PM
BIGCHIEF's Avatar
BIGCHIEF
Default RE: Cruise Light Stays on!!! Help...
Sounds like a simple warranty item....since it is causing you no operating headache, just wait for the next service to be due.
Old Jun 7, 2008 | 04:48 AM
jcbpa's Avatar
jcbpa
Good point.... but annoying... they just fixed it so it wouild work... couldn't turn it on, now it won't go off.&nbsp\\; I'll ride until the next oil change.
Old Jun 7, 2008 | 08:26 AM
BEAST's Avatar
BEAST
Does it stay on with the rocker on the dash turned off? Cause if the rocker is on it will stay orange till you activate it. Then it turns green.
Old Jun 7, 2008 | 08:43 AM
RoadKing_Al's Avatar
RoadKing_Al
Just a guess, but doesn't the Cruise Light have something to do with the heat management system?
Old Jun 7, 2008 | 08:47 AM
Harleypingman's Avatar
Harleypingman
If you haven't done so already, contact the service manager and document the fact that the cruise continues to malfunction\\; also, with the TBW, and the electronic cruise control, I'd be concerned about the malfunction as a safety issuefor all you know there may be a dangerous defect in the ECM causing this malfunction.
Old Jun 7, 2008 | 11:24 AM
jcbpa's Avatar
jcbpa
Rocker switch is off, light is orange all the time.&nbsp\\;
Old Jun 7, 2008 | 11:35 AM
SubZer0's Avatar
SubZer0
Sounds like a bad switch to me.
Old Jun 7, 2008 | 12:29 PM
jcbpa's Avatar
jcbpa
Yeah, but that would be way too simple...&nbsp\\; I'll have to bring it in and see what they say.
&nbsp\\;
Thanks
ggreene59
May 26, 2019 08:59 AM
kitt90
Dec 20, 2014 03:24 AM
dkc061
General Topics/Tech Tips
Oct 25, 2014 08:53 PM
EL ROADKING
Jun 23, 2010 09:05 PM
FLWanderer
Aug 28, 2006 11:55 AM
