pinging update
Old Jun 14, 2008 | 05:48 AM
angelina78's Avatar
angelina78
Default pinging update
as some of you know i have posted a few times on the pinging.&nbsp\\; it drives me nuts, i ride fairly hard so the pinging is not good.&nbsp\\; anyway, for those with the pinging.&nbsp\\; octane helps greatly and it was how i resolved it until now.&nbsp\\; just put colder 4163 spark plugs with no octane and although i have not had a lot of time with them, they seem to make a huge difference.
Old Jun 14, 2008 | 10:58 AM
Bmalloy's Avatar
Bmalloy
6th Gear
Default RE: pinging update
I just added&nbsp\\;the SE Air, pipes and of course the all important download, running on&nbsp\\;91 octane&nbsp\\;and have done about 300 mile on this set up. This reduced my pinging dramatically, to almost non-existant. I might try your suggestion&nbsp\\;and see if it can't be totally eliminated...
Old Jun 14, 2008 | 11:02 AM
Bossman1's Avatar
Bossman1
SOUNDS SIMPLE&nbsp\\; why didn't stealer suggest that???
Old Jun 14, 2008 | 03:05 PM
Getyurmotorunnin's Avatar
Getyurmotorunnin
What did you use to increase you octane?
Old Jun 14, 2008 | 03:24 PM
wydopn231's Avatar
wydopn231
I used lucas octane booster on cross country trip.It help a tone with that lil sob beating the top of my new pistons.I think his arm get bigger as the trip went on or hi hammer bigger,I had few fill ups w/o the booster.
Old Jun 14, 2008 | 05:10 PM
Lincolnhog's Avatar
Lincolnhog
You should not need octane boost in a low compression engine
to avoid ping.
In fact there is a lot of literature that shows 89 is fine.
It detonates at a lower flash point.
I would look at the fuel managment system.
At what rpm is it pinging...????
Linc
Old Jun 14, 2008 | 05:17 PM
TOMCENTRAL's Avatar
TOMCENTRAL
XIEDs.orIEDs.Regards,Tom
Old Jun 14, 2008 | 05:40 PM
xcelr8's Avatar
xcelr8
keep the rpm's in the 2300 to 2800 range for zero pinging.
Old Jun 14, 2008 | 07:30 PM
Lincolnhog's Avatar
Lincolnhog
If you put a gear reduction kit in, you can run 85 octane and never have a problem
and then pull the house down
blackxpress
21
Jul 1, 2017 09:36 AM
ohioflhs
Aug 31, 2015 05:23 PM
rockher_man
May 23, 2014 05:43 PM
1flhtk4me
Apr 21, 2009 07:31 PM
LarryJ00
Jul 24, 2007 01:22 AM
