Motor stalled!!
Old Jun 16, 2008 | 08:03 AM
reecard's Avatar
reecard
Default Motor stalled!!
I have a 2003 EGC EFI with 21,500 miles, it has had a stage on with slip ons.&nbsp\\; Yesterday I was traveling at 60 mph for about 20+ miles, when I came to a stop sign the idle dropped to about 550 rpm.&nbsp\\; Then it stalled, it fired back up and I had no more problems with it.&nbsp\\; Does anybody know what the problem could be??
Old Jun 16, 2008 | 02:16 PM
reecard's Avatar
reecard
Default RE: Motor stalled!!
I called the dealer and thought it could be an air leak at the intake.&nbsp\\; Does that sound right?
Old Jun 16, 2008 | 02:46 PM
ironoxide's Avatar
ironoxide
intake air leak would be constant, not a one time thing, I believe. Consider checking your battery clamps.
Old Jun 16, 2008 | 03:08 PM
garyhendley's Avatar
garyhendley
TO CHECK AIR INTAKE LEAK USE CARB SPRAY WHEN U SPRAY IT THE IDLE SHOULD GO UP
Old Jun 16, 2008 | 04:28 PM
steadyflow's Avatar
steadyflow
mine does the samething once in a blue moon, im clueless iv checked everything
Old Jun 16, 2008 | 04:46 PM
badblue's Avatar
badblue
+1 on check the battery. happened to me and it looks like it was a loose positive cable.
Old Jun 16, 2008 | 06:19 PM
FXSTDSE2's Avatar
FXSTDSE2
If it was a car, I would say the idle Air Control Solenoid got stuck closed during your decell. It is a Delphi component like the ones on a GM car. But check the battery cables and intake seals. I lost a seal at 26k. Hard as rocks cold and the rear one had a crack. The computer controls do try there best to keep it running under most conditions.
imjwag
EVO
17
Oct 31, 2014 08:53 PM
BBLV2RD
Shovelhead
Jul 13, 2011 11:37 PM
LaRider
Exhaust System Topics
Nov 29, 2010 02:46 PM
watercop
Sep 12, 2010 09:59 AM
98glider
Jul 30, 2008 09:11 PM
