think i got some bad gasoline...
Old Jun 16, 2008 | 07:56 PM
dslwraith's Avatar
dslwraith
Default think i got some bad gasoline...
got gas last weekend and it has been running rough and the engined has cut out right after starting
&nbsp\\;
if i let it warm up for 5 or 10 minutes it runs better but still rough
&nbsp\\;
started after this last tank of gas
&nbsp\\;
can i add some octane booster or something else&nbsp\\; to it to help
&nbsp\\;
any advice or suggestions appreciated
&nbsp\\;
bike info
2000 FLHRCI 95" Stage 1 and SE slipons
&nbsp\\;
&nbsp\\;
thanks
Old Jun 16, 2008 | 08:02 PM
sweet07's Avatar
sweet07
Default RE: think i got some bad gasoline...
Could have water in the gas.&nbsp\\; Rubbing alcohol (isopropyl) will dissipate the water.&nbsp\\; Run it dry with a litlle gas on board to get ya to a station&nbsp\\;and NEVER buy gas from the same place again.
Old Jun 16, 2008 | 08:11 PM
cwickgo9's Avatar
cwickgo9
there is also gas dryer that most auto parts have&nbsp\\; - usually in winter - that gets the water out.
Old Jun 16, 2008 | 09:11 PM
dslwraith's Avatar
dslwraith
so do you add the alcohol to the gas tank?&nbsp\\; how much ??
Old Jun 17, 2008 | 09:44 AM
flynlow's Avatar
flynlow
Seafoam works good. It is great for small engines also.
Old Jun 17, 2008 | 09:50 AM
garyhendley's Avatar
garyhendley
what brand gas did you buy ??
Old Jun 17, 2008 | 12:43 PM
dslwraith's Avatar
dslwraith
valero
Old Jun 17, 2008 | 12:47 PM
Bossman1's Avatar
Bossman1
It's all bad nowadays!!! bring back PHILLIPS FLITE FUEL 106 octane no ethanol!!!
Old Jun 17, 2008 | 01:08 PM
bigjon421's Avatar
bigjon421
6th Gear
i had a fuel&nbsp\\;problem and the dealer said (maybe its bad gas) i didnt believe them i get gas at the same place twice a week it turned out to be the quick disconnect on the bottom of the fuel tank it wasnt seated properly they replaced it and the problem went away. two weeks later the sending unit went and the fuel gauge was reading 3/4 of a tank when it was empty. they said it was fixed after two days in the shop i got the bike back and a week later the fuel tank started leaking fuel from under the dash panel ( the dealer had it apart 6 times to fix sending unit and never replaced the gasket around the filler neck)........but they billed harley for warranty work and paperwork says they replaced gasket and they never replaced it.&nbsp\\;&nbsp\\; check your fuel lines first then check your fuel.&nbsp\\;&nbsp\\; its a&nbsp\\;2007 fltr road glide
[IMG]local://upfiles/54393/6994CCE7532F4E728AE535F56ACBCF6A.jpg[/IMG]
Old Jun 17, 2008 | 01:37 PM
stubby's Avatar
stubby
Same thing happened about a month ago. Stopped at an off brand station and filled up, bike ran terrible. Rode it awhile, that day, and filled up at Sunoco. I think either the gas station is getting screwed bt the distributor or the station is knowingly selling a lower octane. I usually get Sonoco 93 when possible.
Try one of the gas additives, if that don't clean it out with fresh gas, something else is going on.&nbsp\\;
