any tips on changing bars on 08 SG
Old Jun 17, 2008 | 05:02 PM
dt20's Avatar
dt20
Default any tips on changing bars on 08 SG
got a new set of wild 1's 575 coming in and thinking of changing the bars out myself.&nbsp\\; just wondering if there is anything i should look out for.&nbsp\\; does the wiring harness for the throttle need to be extended? any tips on running the wires inside the bars?&nbsp\\; got some info from the search but didnt really see all that much in these areas.&nbsp\\; any help will be greatly appreciated.
Old Jun 17, 2008 | 05:24 PM
debay's Avatar
debay
Default RE: any tips on changing bars on 08 SG
Looking for information 2
[hr]
Old Jun 17, 2008 | 07:45 PM
dawg's Avatar
dawg
Don't need wire extensions. For internal wiring you need throttle sensor pn#32310-08. You will need clutch cable pn#38649-08. Everything else is easy.
Old Jun 17, 2008 | 08:05 PM
dt20's Avatar
dt20
thanks dawg really do appreciate it.&nbsp\\; have the shop manual was just wonder if others had some helpful tips on this.&nbsp\\; thanks for the part numbers will be sure to pick them up didnt know i needed those.&nbsp\\; thanks again
Old Jun 17, 2008 | 08:11 PM
dawg's Avatar
dawg
Another tip is to put the scoot wheels up on 2x4/2x6 lumber and lean it way over on the jiffy stand when you pull the tranny side cover to replace the cable. This way you won't spill any tranny fluid and won't have to drain. Also need side cover gasket and exhaust gaskets.
Old Jun 17, 2008 | 08:26 PM
dt20's Avatar
dt20
great tip.&nbsp\\; starting to wonder if I want to do this job![sm=alcoholic.gif]might just be drunk by the time i finish!
Old Jun 18, 2008 | 12:58 PM
Peppa1's Avatar
Peppa1
Assisted friend (ex HD mechanic) in doing mine and we didn't even have to loosen the exhaust from the heads. We removed the 2 exhaust shields and he had a long shank ball end allen wrench and with a air ratchet we were able to loosen and remove the bolts on the tranny cover without even loosening the exhaust. Removed old clutch cable, installed new one, put new gasket on and buttoned it back up. We did drain the fluid, not concerned about saving it. With manual in hand and a friend around to assist with a couple of things I think it is an easy enough job.
Burbur2
Feb 8, 2019 08:49 AM
1liter
Apr 22, 2013 05:23 PM
zamboknee
Mar 30, 2012 03:18 PM
mastery
Jan 21, 2011 07:00 PM
rgm
Mar 15, 2008 06:17 PM
