It seems odd to me but with my 08Ultra I get better milage cruising in 5th gear than in 6th.
I normally set the cruise at 70 to 72 and have the \\;Miles Remaining indicator on to kind of monitor what is going on, if I switch from 6th to 5th gear the miles remaining will go up. \\; At 5th gear the bike is doing maybe 3100 RPM or so, in 6th probably in the neighborhood of 2650 to 2700 RPM.
Could it just be that the \\;engine is struggling \\;a little bit in 6th, but the RPMs are high enough in 5th to be in the Sweet Spot so to speak? \\; It is really noticable in a strong headwind.
I have a PCIII, SE Mufflers, \\;and a SE Air Filter on the bike now if that makes any difference.
Thanks for your thoughts, Ride Safe
Ain't possible - that would indicate that the engine is close to lugging, an' from all the geniuses postin' elsewhar, we KNOW that ya can't lug an engine!<\\;SEG>\\;
Someone posted something about keeping the revs up and getting better mileage on the 07 and 08 6 speeds. \\; I've been experimenting a bit and the results are somewhat inconclusive. \\; However, it appears it's true. \\;
Staying out of 6th until above 2700rpms on highways, etc seems to improve mileage.
Counter intuitive, but possible I guess...Although the brain keeps saying NO! \\; Remember 6th on the HD is not the same as 6th on a Baker. \\; Still 1:1 ratio in 6th, and the old 5 speeds were also 1:1. \\; Gearing and sprockets are different. \\; Still, doesn't make sense that's possible.
I did the 6spd on my 2000 EG STD and the 96 hop up. \\; Seems to do well above 3K. \\; Headwind is a problem and 5th seems to be the sweet spot. \\; On good day at 80 in 6th seems to be fine as long as radar isn't out issuing tickets.
So does the gear reduction change the trans gear or do you change the sprockets?
I have also noticed that 6th gear is pretty much useless until about 85-90 mph.
I'm experiencing the same thing on my 08 Ultra. Seems to get better mileage in 5th on windy, hilly raods then on the flat superslab when I put it in 6th gear. I thought maybe it was a break-in thing, but I've got 6,500+ miles and it seems to stay consistent as stated above.
+1 here to...noticed it on vaction. \\; Started getting some good MPG when I waited longer to get to 6th. \\; At 80 6th is almost useless. \\; That is about my max most of the time....did some 85-90 on vacation on big long stretches but the rest is 80 an under.
I've been finding the same thing. I am hardly scientific about it. \\; My riding is mostly country State Roads. \\; I've noticed that when shifting from 5th to 6th it takes a fair amount more throttle to maintain the same speed. \\;
