I hear a clunk up front, while braking
Old Jun 27, 2008 | 12:21 AM
ratcat's Avatar
ratcat
Default I hear a clunk up front, while braking
So on my 08 ultra, driving around town, I hear a clunk some where up in the front end.&nbsp\\; Not every time, about 1 in 5 times&nbsp\\;I go to stop.&nbsp\\; It seems to happin as I pull in the clutch and apply the front brake.&nbsp\\; I have checked every fastener on the forks and brakes.&nbsp\\;
Any Ideas?
Old Jun 27, 2008 | 12:29 AM
drrandall1's Avatar
drrandall1
Default RE: I hear a clunk up front, while braking
I am getting the exact same noise. My bike was at the dealer for a week and the service manager finally took it for a ride and said he heard it and was going to call HD directly to see if there was a problem. About 1 outta 5 for me too. Anyone else having the same issues? I have put 1000 since then.
Old Jun 27, 2008 | 12:31 AM
Billiam92407's Avatar
Billiam92407
I get the same thing...&nbsp\\;\\\\\\;a little less frequently though&nbsp\\;\\\\\\;maybe one out&nbsp\\;\\\\\\; ten. I have about 6500 miles.
Old Jun 27, 2008 | 12:36 AM
drrandall1's Avatar
drrandall1
WTF! What could it be? The end of Summer I am going to have them take it apart. That noise can't be a good thing.
Old Jun 27, 2008 | 05:59 AM
AR4CE's Avatar
AR4CE
Do you have floating rotors?
&nbsp\\;
I had floating rotors on my '06 and they would clunk most times the first time I used them in the morning, but then were silent the rest of the day.
&nbsp\\;
I havn't had the same noise on my '07, but I also have not ridden in almost 6 months either.... damn desert...
Old Jun 27, 2008 | 06:12 AM
slankard's Avatar
slankard
Just a thought are the neck bearings loose? That would cause some play and movement which would cause the noise.
Old Jun 27, 2008 | 07:00 AM
Big Peter's Avatar
Big Peter
Check the anti rattle springs
in front calipers.
Are they properly installed ?
I've had the same issue.
&nbsp\\;
Peter
Old Jun 27, 2008 | 07:06 AM
masterblaster's Avatar
masterblaster
Yep same issue, just installed the floaters two weeks ago thats when it started. Just about to post when I seen this, will get the head bering checked anyway though.
Old Jun 27, 2008 | 08:48 AM
drrandall1's Avatar
drrandall1
Good things to have checked. Thanks for all your input guys
Old Jun 27, 2008 | 09:19 AM
IBHarley's Avatar
IBHarley
I have it to but thought it might be the front brake pads hitting the pins when applying the brakes lightly only at slow speeds like when I enter the garage&nbsp\\;&nbsp\\;&nbsp\\; I will wait to see what others find out
