Lowering 2007 StreetGlide
Old Jul 1, 2008 | 07:10 AM
07flhxindy's Avatar
07flhxindy
4th Gear
Default Lowering 2007 StreetGlide
I lowered the rear of my Streetglide with bracket on the rear shocks. Twice now the rear tire has rubbed the wiring harness on top of the inside of the rear fender. What does everyone else do to fix this problem? Thanks
Old Jul 1, 2008 | 11:05 AM
shooter64's Avatar
shooter64
Former Sponsor
Default RE: Lowering 2007 StreetGlide
Your glide is already 1" lower than stock, what brand brackets did you use, and does it only rub riding two up
Old Jul 1, 2008 | 12:09 PM
07flhxindy's Avatar
07flhxindy
4th Gear
The bracket are TWR from ebay. Yes it rubs riding 2 up. With the brackets my feet are flat thats the only reason I put them on. I've seen other bikes lower than mine with no problems I guess.
Old Jul 1, 2008 | 01:22 PM
gibbyflhx's Avatar
gibbyflhx
how much air do you have in the shocks? I have the same setup and have not rubbed with a passenger. I usually run about 38 in the rear shocks
Old Jul 1, 2008 | 01:38 PM
Primo's Avatar
Primo
There is a rubber/foam/whatever shroud that surrounds the wiring harness that comes with an adhesive backing that glues the wiring harness to the underside of the rear fender. You could get that shroud from the dealer then relocate the wiring harness to the crease underneath the fender where the top and the side of the fender meet, away from the path of the rear tire.
I have an air ride system and after 10k miles (sometimes too low evidently with a passenger) it was starting to wear thru the shroud. My mech at the dealer recommended the relocation and it solved the problem.
Good luck,
Primo
P.S. Feel free to PM me if the explanation was not thorough enough.
Old Jul 1, 2008 | 02:09 PM
07flhxindy's Avatar
07flhxindy
4th Gear
Thanks primo!! That's a good idea for the harness. Had to order the harness today and when I get it I will try to relocate harness if long enough. I run about 10 to 40 psi on the shocks.
Old Jul 1, 2008 | 02:17 PM
Terminator69's Avatar
Terminator69
I put on a set of the progressive 440's that are 11.5 eye to eye, And I sent my seat to Allen at mean City&nbsp\\;cycles here on HDF and&nbsp\\;he reworked it for me.&nbsp\\;I'm 5'8 with a 30" inseem and I can sit flat footed with sneakers on, and it also helped with the buffeting from the 4'&nbsp\\;windsheild. Just my .02&nbsp\\;&nbsp\\;&nbsp\\; &nbsp\\;&nbsp\\;&nbsp\\;T&nbsp\\;
mpr3369
Air Suspensions
Apr 13, 2013 08:51 AM
smithbrl
Mar 20, 2011 02:12 PM
jordanball33
Dec 1, 2008 08:10 AM
hwyjunkie
Jun 23, 2008 01:18 AM
HDFLHT
Mar 21, 2007 12:30 AM
