Kuryakyn run turn flash question
Old Jul 1, 2008 | 07:16 PM
jeff194's Avatar
jeff194
Default Kuryakyn run turn flash question
I have the Kury run turn flash module on my 07 UC. I am running standard filiment bulbs front and rear. Do I need the load equalizer? Mine came with one, but it fried for some reason, and was causing the signals to malfunction. I unplugged the equalizer and everything works fine, even the alarm. So does anyone know if the EQ. is neccesary?&nbsp\\;
Old Jul 1, 2008 | 07:23 PM
alstrud's Avatar
alstrud
Default RE: Kuryakyn run turn flash question
No...only when using LED lights because they draw so much less current than incandescent. The load equalizer acts like you have regular lights everywhere...not LEDs. The system thinks LEDs are burnt out light bulbs even though they work. That's why it flashes fast. Since you're using regular lights...no equalizer needed.
Old Jul 1, 2008 | 07:38 PM
Q Hog's Avatar
Q Hog
I have a two load equalizer. One for the front and rear.
&nbsp\\;
&nbsp\\;
jeff194's Avatar
jeff194
Ok, that's probably why the EQ fried then. I just didn't want harm anything&nbsp\\; without it.
ricopoco
Aug 20, 2012 09:55 PM
countabill
Mar 9, 2011 07:16 PM
bobalou1999
Mar 3, 2008 11:34 AM
SmoothRider
May 5, 2007 11:54 PM
AsahiToro
Mar 16, 2007 11:45 AM
