Strange noise
Old Jul 1, 2008 | 07:46 PM
Lowly_G's Avatar
Lowly_G
Default Strange noise
I have a 2006 EG Classic. When i accelerate from 2500 rpm's I hear a strange&nbsp\\;noise from the engine, I think, towards the front left side. It sounds like loose metal being moved around. I can not isolate the noise. It does it almost every time. Any ideas?
Old Jul 1, 2008 | 08:13 PM
electaRICK's Avatar
electaRICK
Default RE: Strange noise
primary chain might need adjusting?,, spark knock??
compensator sprocket? cam chain shoes?
Old Jul 1, 2008 | 08:15 PM
Spartan's Avatar
Spartan
What type of fuel are you using? Have you recently done any mods to the bike?
Old Jul 1, 2008 | 08:25 PM
Lowly_G's Avatar
Lowly_G
I only run super unleadedthrough it. The only mods are a SE big bore kit with 203's in Jan. 07. I have about 10k miles on it since the big bore was installed. I just changed all fluids and saw no metal on any of the magnetic plugs. I am curious if it is because I do not have a good tune on it. I only have the canned download from Harley..
Old Jul 1, 2008 | 08:48 PM
Spartan's Avatar
Spartan
ORIGINAL: Lowly_G
&nbsp\\;
Then it could very well be a timing issue...... Do you have a SERT? If not, you may want to invest in one.......
Old Jul 1, 2008 | 10:50 PM
Lowly_G's Avatar
Lowly_G
Thanks Spartan... was looking at the auto tuners since like the DTT. I will one day put together a better engine build and have that ready to go.
Old Jul 2, 2008 | 12:11 AM
GasCan's Avatar
GasCan
Hold the front brake and put a load on the motor to see if you hear the noise. If so and it sounds like a knock, you might have a bad bolt on the compensator or perhaps a bolt that has backed off.
Old Jul 2, 2008 | 06:09 AM
jbhawley's Avatar
jbhawley
A couple questions:
Does the sound change tone or pitch as you increase or decrease in speed?
Can you hold in the clutch and keep the throttle at the smae rpm asn produce the smae noise or does it go away?
Does it sound more like an engine noise or metal striking metal, as in, a shield clanging against something?
Have you recentlyu added any chrome do-dads such as engine covers, spark plug covers, etc.
RCermak
EVO
Jul 12, 2016 11:21 AM
jgcable
Aug 11, 2014 06:15 PM
cam2zap
Jan 19, 2014 01:28 PM
rbabos
Sep 10, 2008 10:47 PM
jbt
Exhaust System Topics
May 16, 2008 11:50 AM
