While at Deals Gap I ran into another rider who had "true dual" on his RKC from what I saw the only difference aside the dia. is bigger is the cross over pipe on the rear engine was removed. \\; My question are: \\; \\; What benefit \\;does that cross over have since all it does is dump exhaust from the rear engine to front engine pipe? \\; What benefit will it have to remove that from \\;from the OEM exhaust and just have slip on's? \\; thank you in advance.
When I switched to TDs, I noticed a little loss of torque in the low RPM range due to decreased back-pressure. \\; The tradeoff was well worth it as once you get into the 3000 RPM range, the motor is noticeably stronger. \\;
My reason for switching was the heat issue. That crossover builds and holds a lot of heat that seems to radiate directly to your right thigh/crotch area. I noticed a slight drop in low end torque but nothing anywhere close to what I had expected after reading a lot of info on here. To me, switching over to the TD's was the best mod I could have done without major engine work. I couldn't be happier with the results. My bike runs better, runs way cooler and sounds fantastic.
While at Deals Gap I ran into another rider who had "true dual" on his RKC from what I saw the only difference aside the dia. is bigger is the cross over pipe on the rear engine was removed. \\;\\\\\\; My question are: \\;\\\\\\; \\;\\\\\\; What benefit \\;\\\\\\;does that cross over have since all it does is dump exhaust from the rear engine to front engine pipe? \\;\\\\\\; What benefit will it have to remove that from \\;\\\\\\;from the OEM exhaust and just have slip on's? \\;\\\\\\; thank you in advance.
The cross over pipe takes advantage of the scavenge effect, giving you the simulated performance of a 2 to 1 pipe. On a Harley the left exhaust is mostly for appearance. Even the muffler is different than the right muffler in an attempt at balance.
True duals loose some low RPM torque due to the loss of the scavenge effect, but make up for it at higher RMP's because they usually have less restrictive mufflers. \\; True duals will spread the heat from the rear cylinder &\\; the cross over pipe a little more evenly, &\\; so reduce the heat problem on your right leg. \\; A 2 to 1 pipe with the rear cylinder exhaust bent forward will do nearly the same thing while keeping the performance of the scavenge effect, but you loose the balanced look of dual exhausts. Everything is a trade............<\\;shrug>\\;
SAME THING..VERY LITLE TORQUE DROP BUT VERY BIG DIFF IN HEAT ON THE LEG.
I HAVE 'CORED" STOCK MUFFLERS AND THE SOUND DID INCREASE BY ABOUT 20% LOUDER
Don't want to sound cheap or anything but since I have collect several fabrication tools I was thinking of removing the cross over pipe from the OEM exhaust. \\; From studying it I should be able to cut it off and weld it shut and still be able to cover that area with the crome heat shield.
Don't want to sound cheap or anything but since I have collect several fabrication tools I was thinking of removing the cross over pipe from the OEM exhaust. \\;\\\\\\; From studying it I should be able to cut it off and weld it shut and still be able to cover that area with the crome heat shield.
Why not? \\; Cheap is good! \\; Just look at the mufflers, they're not identical. \\; You might want to go to an aftermarket set.
Not all years have different mufflers. Some years thay are the same.
That is my understanding as well. It seems that whatever was done previously, when they went to O2 sensors front/back they went to differing mufflers left/right.
