Magneti-marelli tooth reference
Old Jul 2, 2008 | 08:12 PM
wdelarosa's Avatar
wdelarosa
Stage II
Default Magneti-marelli tooth reference
Can anyone out there tell me what tooth on the flywheel should be aligned with the crank sensor when #1 is at TDC, compression? I'm converting carbed to EFI and the Magneti-Marelli system was all I could afford. I'm cutting the teeth on my flywheel with HAWS CNC and then bore my case for the sensor. Any help would be appreciated.&nbsp\\;
Old Sep 20, 2008 | 08:50 AM
fxrs88apes's Avatar
fxrs88apes
2nd Gear
Stick to a carb, The trouble your going through to put the Magneti Marelli system on??? Theres a reason harly went to the Dephi
I'm having a difficult time diagnosing my beefed up 98 Ultra with a power commander. If you can get your money back and save up for a ThunderMAX. That's what I'm planning to do
troverman
Apr 11, 2017 02:28 PM
pecostx
EVO
13
Aug 25, 2014 07:16 AM
yzergod
Sep 16, 2013 10:25 AM
dtfly
Sep 8, 2011 04:34 PM
DPete
Aug 11, 2011 03:44 PM
