"Click" when letting out clutch
Old Jul 3, 2008 | 10:10 PM
sparky_mo's Avatar
sparky_mo
Default RE: "Click" when letting out clutch
I have an 07 with the IDS added and it&nbsp\\;makes the noise you are describing. Head mechanic at&nbsp\\;my dealership says it's the rubber in the IDS stretching and snapping back when letting out the clutch. Says it's not a big deal. Makes sense to me.
Old Jul 3, 2008 | 10:41 PM
serverpimp's Avatar
serverpimp
Default RE: "\\;Click"\\; when letting out clutch
The wife's SG does it, the Ultra doesn't.&nbsp\\; As long as it keeps going down the road I'm happy.....
Old Aug 20, 2008 | 10:33 AM
Cloud09King's Avatar
Cloud09King
My '09 FLHRC is doing this now? It's making a "click" sound when I bring the clutch in to shift into 2nd gear & sometimes 3rd gear as well? It's at the stealership right now getting looked at. Glad I read this thread today though...will make me feel a little better if they do tell me it's a "Harley thing"!
Old Aug 20, 2008 | 05:09 PM
heavymetalthunder's Avatar
heavymetalthunder
my 08 RG does it also. I notice it the most when I pull in the garage and pull in the clutch put it in neutral and release it. Glad to know it's not just big Red doin' it. I thought the dealer jacked it up on my 1,000 mile service. I wasn't pleased with their service and won't go back unless forced to do so. Ride safe
Old Aug 20, 2008 | 05:13 PM
crash1292's Avatar
crash1292
Originally Posted by hotshot
Thanks guys,&nbsp\\; when I go up to the dealer (100 miles away - that stinks) I will get them to look at it, but I feel good that it's a "Harley" thing after reading your posts.&nbsp\\; I appreciate the input.
My biggest complaints with the '08 Ultra are the heat and the problem with the new throttle control
The heat, I've got RJ Orginal deflectors, but it still gets pretty warm.&nbsp\\; Better with RJ's, but still hot.&nbsp\\; Thinking of trying an oil cooler and/or true dual pipes.&nbsp\\; Anyone with experience with these?
Also, the new throttle control, no standard throttle cable.&nbsp\\; Sometimes, the idle gets off... it will idle at a wrong rpm or do this weird fluctuating idle.&nbsp\\; Right now the only fix the dealer has is to cut the ignition switch off, then on for 10 seconds then off, then on for ten seconds, then off, then on for 10 seconds, then off then on for 10 seconds (4 cycles).&nbsp\\; This puts the throttle back to default and all is good again until the next time.&nbsp\\; This little deal has happened to me 4 times now.&nbsp\\; It's really not a problem, more of an inconvenience.&nbsp\\; I would like it fixed.&nbsp\\; Hope HD is going to find a more permament fix.
The throttle control is fine except for this.
Well now you know my story.... hehehehhee
thats nothing.....wait till your fuel filter comes apart and leaves you stranded
Old Aug 20, 2008 | 07:05 PM
jack49's Avatar
jack49
My 06 has done it from day one,never been a problem.
Old Jan 20, 2009 | 05:22 PM
Cloud09King
Just curious...you guys still hearing this "click"? Find out any new info on this? I'm gonna get a 3rd opinion this Spring. The 1st dealer told me it was a chain tensioner-related sound & normal. The 2nd dealer told me what I was hearing was the metal in the front brembo brakes & also normal? He even dupliacted the sound for me! Not sure what to believe though?
Old Jan 21, 2009 | 01:46 PM
bnelele's Avatar
bnelele
Mine occasionally does it to. My hearing is not all that great but i've noticed when I roll back out of a parking place then put it in gear to roll forward and let out on the clutch I get a click, but I think it is the front brake puck taking up slack in the forward direction
Old Jan 22, 2009 | 08:15 AM
hawg08's Avatar
hawg08
Whewwwww! I'm glad this issue is more widespread than just mine. One less thing to worry about now. The only thing that bugs me is than NONE of my previous Harleys made the "CLICK" noise. New technology maybe?
Old Jan 22, 2009 | 02:25 PM
Cloud09King
That's how I felt when I heard that I'm not the only one experiencing this annoying "click". I swore that I had bought a lemon when I first heard it! Had never heard it before on any of my last 4 bikes?
terrible1one3
13
Jul 28, 2013 11:28 AM
taterbum
May 11, 2013 10:55 AM
DJFireUSA
Sep 7, 2009 07:42 PM
sparky_mo
May 22, 2008 04:22 PM
steinmetze
Nov 17, 2007 08:34 AM
