What last minute things.....
Old Jul 2, 2008 | 11:48 PM
soos's Avatar
soos
Default What last minute things.....
have you done to your scoot before leaving on a trip? I have a ferry to catch on friday morning at 7 am and I am doing my rear brake pads on thursday.
Old Jul 2, 2008 | 11:52 PM
74_ironhead's Avatar
74_ironhead
Default RE: What last minute things.....
I went from this.....
to this...
I had two days to do it before I went to the HDF Rally, I packed lots of extra tools and never took a test ride before taking off on a 1500+ mile weekend
Stupid.. probably..... Worth it, YES!!!
Old Jul 3, 2008 | 12:00 AM
TexasRedneck's Avatar
TexasRedneck
Sorry, guys - ah do NO significant maintenance/repairs fer 2 weeks prior to any trip, unless thar's no other choice.&nbsp\\; Just ain't worth findin' a problem with the work!
Old Jul 3, 2008 | 12:55 AM
dawg's Avatar
dawg
Make sure you check the effin nut on the heffer shaft!&nbsp\\; Blinker fluid too.
Old Jul 3, 2008 | 08:38 AM
Paniolo's Avatar
Paniolo
Starting from the front and working your way back, check and tighten every nut and bolt you can reach. You will be surprised how may turn a quarter to a half rotation. Saves you from having stuff vibrate loose while on the road.
Old Jul 3, 2008 | 08:42 AM
ridesegc04's Avatar
ridesegc04
tire pressure and if your running tubeless tires get a pump and plug kit.
Old Jul 3, 2008 | 08:49 AM
UltraKla$$ic's Avatar
UltraKla$$ic
Don't forget your blow-up doll!&nbsp\\;Ride safe, check in and take a TON of pics.
No pics?&nbsp\\;Don't come home![8D]
Oh yea, top off the radiator with quality top-shelf antifreeze.&nbsp\\; It can get hot on that Ultra.[8D]
Olde Skool's Avatar
Olde Skool
+1 on what TexasRedneck said...Not a good idea to do sumthin new before a trip unless you have a chance to run it in &amp\\; shake it down to make sure there is not a problem with the repair/mod...
Old Jul 3, 2008 | 08:54 AM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
ORIGINAL: UltraKla$$ic
No pics? Don't come home![8D]
Oh yea, top off the radiator with quality top-shelf antifreeze. It can get hot on that Ultra.[8D]
+1 on the blow-up doll. It can get mighty lonesome out there. &nbsp\\;
Old Jul 3, 2008 | 08:56 AM
JBaker421's Avatar
JBaker421
How far are you going? Check your tire tread. What looks like a good 50% tire now can be gone in 5,000 miles, or dangerous in 3,000.
