Proper Washing Technique
Old Jul 4, 2008 | 08:30 AM
BigDaddyMike's Avatar
BigDaddyMike
Default RE: Proper Washing Technique
Bath towels are made of cotton which is a wood fiber and WILL scratch the clear coat!
Old Jul 4, 2008 | 08:31 AM
nedster's Avatar
nedster
make it a RAT bike, no washing allowed
Old Jul 4, 2008 | 08:36 AM
2006ultra's Avatar
2006ultra
The first thing I do is cover the gauges and the radio with a garbage bag.&nbsp\\; I hang it from my three puches on the dash.&nbsp\\; I got my radio wet right after I bought the bike and the radio display quit working for a few days then came back on.
&nbsp\\;
Put bike on my sears bike jack to level it so I can get to the wheels easy.
&nbsp\\;
Then I hose as many of the bugs off as I can and give them time to soften up.&nbsp\\; They will scratch if you scrub.
&nbsp\\;
Good old micro fiber mit and car wash soap.&nbsp\\; Do not wash in sunlight or when paint is hot from sun.
&nbsp\\;
Rinse with Mr Clean gizmo so you are using soft water.
&nbsp\\;
Blow dry with leaf blower, water will fly off the bike when rinsed with soft water.&nbsp\\; Blow all the buttons and crevices out.
&nbsp\\;
Polish paint with Mcguires finish spray and micro fiber cloth and chrome with windex.
&nbsp\\;
A good coat of wax is a great idea especially on the fairing.
&nbsp\\;
I can do all this in 20 minutes give or take if i have to.
Old Jul 4, 2008 | 09:09 AM
mastery's Avatar
mastery
ORIGINAL: StreetGlide2006
I don`t wash my bike. I keep a good coat of wax on it and after riding I use Maguire's polymer detailer on it. Great for bugs and everything else I have run across. I use quality microfiber cloths from \\\\\\;www.autogeek.net
Everything said above is what I do. Autogeek's got a great price on the microfiber towels too, I buy them by the dozen each year.
Old Jul 4, 2008 | 09:12 AM
lionsm13's Avatar
lionsm13
I tried S 100 a while back as my local stealership said that it was the sheet, however I found that it left a filmy coat of crap on it. Needless to say won't use it again.
Old Jul 4, 2008 | 09:49 AM
EasternSP's Avatar
EasternSP
I use engine cleaner on the underside of the engine and tranny to get the road grime off.&nbsp\\; I use a tooth brush to loosen what won't come off with the rinse cycle.&nbsp\\; Nothing like a clean underside of the scooter when leaning into the turns.&nbsp\\; 8-)
Old Jul 4, 2008 | 11:20 AM
skratch's Avatar
skratch
Not many coats. Use a good wax and you only need to do it once a year. I have vivid black and wax it over the winter and buff out any marks I have collected during the riding season. Then I wax it and am good till the next winter. Using good microfiber clothes makes a big difference in not getting the fine scratches on the paint that other rags leave.
Ride Safe,
Mike
depending on the wax you use, you may just be wasting your time if you try to put a bunch of coats on it.&nbsp\\; most waxes are actually cleaner/waxes so they remove the old wax and replace with new.&nbsp\\; so every time you try to add another coat, you're just exercising your forearm muscles.
also, i use meguires skratch-x to get rid of all those fine scratches (like around the gas cap).&nbsp\\; its safe for clear coat and works great.
i've lately been using peroxide on the bugs (as per a tip from the forum here).&nbsp\\; spray it on, they wipe right off.
Old Jul 4, 2008 | 11:39 AM
PA SILVERBACK's Avatar
PA SILVERBACK
I hardly ever wash with a Mit or sponge.. I bought a li electric pressure washer from Wally world (1500PSI) and Use that when the Bike starts getting Grimey.I use Purple power on the Motor wheels and Tires .Then use an absorber to get the Water off the paint and an air compressor to dry the motor... For a Quick Detail I use Lemon Free Pledge and two Micro fiber cloths,The first one to wipe it off,and the second to make sure all the streaks are gone...
&nbsp\\;
Since the Purple power strips wak,Go over the bike with your favorite wax, Mines Zymol
Old Jul 4, 2008 | 11:46 AM
kart11's Avatar
kart11
Purple power is too harsh if you have a black/chrome engine after time it will definetly dull the black fins on your engine.....ask me how I know!!!
Old Jul 4, 2008 | 12:08 PM
woodeyewetzel's Avatar
woodeyewetzel
The only wau to wash a black bike is with a MR.Clean. If you do not wet the bike good you will end up with small white scatches that you can not buff out. As far as the water spots-there are no spots when using the MR Clean machine even if you wash it in the sun
