engine problems
Old Jul 7, 2008 | 09:35 PM
Northside's Avatar
Northside
Default RE: engine problems
ORIGINAL: ewy66
its not the head gasket that Im concerned about. From what Im being told the crank is out of alinement. and the fly wheel should be welded .
&nbsp\\;
Who told you your "crank" or flywheel assembly is out of alignment?&nbsp\\; How much runout do you have on the pinion shaft?&nbsp\\; Do you even know or is it more people saying they heard.... and other repeating it?&nbsp\\; You can easily check the pinion runout runout by removing the nosecone and using a finger type dial indicator.&nbsp\\; While it's a good idea to weld the crankpin in high horsepower severely run motors, I wouldn't worry about it if it was already assembled and your not running a&nbsp\\;really hot 110".
Old Jul 7, 2008 | 09:44 PM
Wassup8687's Avatar
Wassup8687
ORIGINAL: Spartan
If the dealer failed to tell you AND PUT IT IN WRITING that it would void your warranty, then it's on them. If the MOCO doesn't cover it, take the dealer to court.
Sounds like a good idea. If they did the work and never told you it would void the warranty that's BS. Tell them you never would have had the work done if you knew that.
Old Jul 7, 2008 | 09:45 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
im freinds with a service manager hes seen more problems with scorched piston skirts on the 110 than crank problems put a cooler on it
ffsaulshd
May 11, 2009 06:45 PM
Kodeman
Custom Models
Jan 29, 2009 10:55 AM
wbogley
Shovelhead
Jul 28, 2008 01:00 AM
Fritzwm
Exhaust System Topics
Jun 26, 2008 10:23 PM
mariofleur
Oil Archive (no new posts)
Apr 26, 2008 08:31 PM
